You cannot quote but rubbished my cost estimates for quality work.
I specifically mentioned quality machine work costs vs a basic die -- giving generally poor results.
Does Your plan of attack include go/no go gages for threads You have not done before.
Do You plan to qualify ie measure the thread pitch of the parts.
Does Your cheaper plan include availability to actually somewhat check root, crest, radius, thread d, of the threads ?
I did NOT indicate the parts would be expensive to 3-5k$ plus.
I indicated that the original OPs inferred quality engineers, management, qc, verified gaging, would result in such costs, ballpark.
As I read the post.
E.
I can easily make a similar thread for 100$ qty 1 (die cost), and 10$ each, later on.
It would not be very good quality, and might struggle to be to 2A/2B standards.
2.
Single-point turning in this case, will make excellent threads of great surface finish, with the right R in roots and crests.
These will be to 3A/B standards, or better, on a CNC lathe.
Yes, they will be great but unless one can
prove / document it, the value of the quality mostly does not exist.
Add costs of thread gages, pitch d micrometer with suitable anvil, operator, time.
Liability or rework if some part is wrong.
Margin to cover stuff.
My post estimated running time of less than an hour, for 33 pcs.
That does not mean total costs of 1 hr x 250$ shop rate, at all.
Imo.
Ime.
I doubt we are far apart - and suspect we read different intentions from the OP.
I can't quote off of the drawing in this thread. A lot of guys quote without all the information, that isn't me. I need to know the dimensions before I know the best plan of attack. If the drawing is to scale it looks like a one piece part that would be real simple on a Swiss style CNC Lathe. Or it could be best to second op the thread on a fixed headstock lathe using a split bushing and a collet closer. The op left a lot of details vague.
