RFQ needed
Likes Likes:  0
Results 1 to 2 of 2
Thread: RFQ needed
    Jun 2014
    Dover, DE USA
    164
    42
    Default RFQ needed
    Attached are two PDF's of what i need. QTY is 1 of 110x-410 and 2 for 110x-541. I also have solidworks part files if needed. Thanks.
    Jason
    Dropbox - 110X-541 Rev A Turn & Feed Jaw Container, Chuck, Housing, Carriage, CM-71199.PDF - Simplify your life
    Dropbox - 110X-410 Rev A Turn Shaft Gear, CM-71992.PDF - Simplify your life
    I can be contacted at [email protected] for any further question, or through PM. Thanks
    Jul 2006
    Hillsboro, New Hampshire
    6,775
    1608
    4729
    On the Turn and Feed Jaw Container, I think you'll want to fix the tolerance for the 9.93* angle, as it seems to read 9.93* +/- 10* at the moment. If I'm misreading it let me know.
    Edit - I see with zooming in that there's a decimal, so it's +/- .1 degree. So never mind on that comment...
    Adding some surface finish requirements may be useful too on that ramp - it may benefit operation to be smoother than 63. And if you can add some corner radii to the insides of the ramp it'll be more resistant to cracking, just clear the mating parts to suit.
