RFQ-One 3/8"-8 RH Thread Acme Tap
Likes Likes:  0
Results 1 to 6 of 6
    Oct 2006
    USA Kansas
    85
    5
    5
    Post
    Hello I need a 3/8"-8 tap made. Tap doesnt need to be a tamdem style. The thread is pretty agressive at 2turns/inch.The screw Im using is a Mcmaster-Carr part #99030A303. The tap will be used to thread Delrin rod only. Thankyou Steve
    Dec 2005
    seekonk, ma. 02771
    273
    Post
    steve: i have a .370-8 3-g rh hss acme tap. $40.00 if you can use it. kenny 1-800-592-5912
    Jul 2004
    Houston, TX USA
    29,348
    Post
    At "two turns per inch", he is talking multiple start
    John
    Oct 2006
    USA Kansas
    85
    5
    5
    Post
    Ive tried Roton for a tap. Said they had to have it made.Said it would cost 250.00, still waiting on the call.It will be chucked into my lathe tailshaft.Drill rod is hard enough. If I cant have one made I will taper and cut flutes into a screw I have. Steve
    Jan 2003
    Canada
    11,157
    5189
    3291
    Post
    4 starts... you'll pretty nearly have to broach that thing. Trying to turn it in like a normal tap likely won't do much. Using the threaded rod itself likely won't give you any clearance either.
    Sounds like fun.
    Oct 2006
    USA Kansas
    85
    5
    5
    Post
    Yep its a 4 start. Steve
