Just need a simple riser to put into the bed of my press brake to lift my 4 way die.
Material is nothing fancy, just plain carbon steel. Not sure if aluminum would be suitable. It's only a 25T brake and I'm definitely not using all 25T. I can make the clamp plates.
Quantity is 3.
Figure these can be shoved into a USPS flat rate.
Edit: Didn't know the image was going to compress.
Dimensions:
60mm deep (2.362 in)
3.75 inches tall
11 inches wide
0.55 inch wide slot that's about 0.75 inches below the top and about 2 inches from the edge. Just needs to cradle a 1/2 bolt.
Quantity is 3.
Dimensions:
3.75 inches tall
11 inches wide
