I have some aluminum parts that need to be fixed. It's a tube shape with two grooves for ball bearings. The issue is that the grooves are not perfectly oval so the ball does not sit evenly in each groove.Take a look at the attached drawing. The grooves should be 8.30mm diameter. I think currently they are close but just not perfectly round. Very little metal needs to be removed. Standard tolerance. I have 50 pcs. Drawing is in millimeters. Thank you
I have no idea why I am not able to display a full size image. Here's a link to the pic Shared album - Lem Nirob - Google Photos
