RFQ for rolled bar rings
Results 1 to 16 of 16
    Feb 2005
    Fishersville VA
    1,821
    8
    84
    Default RFQ for rolled bar rings
    OK, just working on a project but would like some idea of the cost for 75 rings made from 1/4x2 bar (hot roll carbon )
    lets say 12" inside dia,...... not aerospace here, so 0.000 to plus .250 is fine.....
    Prefer the ends not to be too flat...LOL
    I just don't own a roll bender....yet anyway
    Pm is fine.
    Thks
  2. Likes jeffk liked this post
  3. #2
    Aug 2002
    West Unity, Ohio
    27,543
    7891
    9660
    Is it possible to not have the bar flat the distance from the two rolls until after welding and running it back through?
    Think Snow Eh!
    Ox
    Feb 2005
    Fishersville VA
    1,821
    8
    84
    could be run back thru....
    the lack of any responses has me looking for other ways to either re-design the product or purchase a machine.
    Aug 2002
    West Unity, Ohio
    27,543
    7891
    9660
    OK, so you are expecting welded and re-rolled rings then.
    When you said "ends" I thought that you was just looking for rolled, but unwelded rings.
    No - I'm not able to make, was just wondering if it was possible to make them rad all the way to the end if not welded and re-rolled.
    (I'm not a fab guy)
    Think Snow Eh!
    Ox
    Feb 2005
    Fishersville VA
    1,821
    8
    84
    Sort of just put it out there.............
    figured we could hash out the details later.............
    May 2002
    South Central PA
    14,613
    2841
    4350
    Quote Originally Posted by MwTech Inc View Post
    Lots of fab shops can do that, but they are probably not on a machining site. Have you looked for tubing the right size?
  8. Likes woodchuckNJ liked this post
  9. #7
    Oct 2005
    22,051
    (I'm not a fab guy)
    Think Snow Eh!
    Ox
    I've seen it done....full weld, flip over back gouge and weld again.
    Grind perfectly flat.
    problem is, when re-rolling, you get too much bend going and then "boing" you've ruined
    them.
    Local shop either pre-bumps the ends in the press brake, for a sort of solution, or rolls
    extra length, and then trims the flat ends off.
    Higher production will full weld, and then run on an expander to stretch, and size them.
  10. #8
    Aug 2002
    West Unity, Ohio
    27,543
    7891
    9660
    Just to be clear - I was not challenging you, I was honestly wondering how that would work.
    I have machined many rings that had been rolled and welded, and I get a cpl fab magazines that have many ads for breaks and rolls, and I just look at those rolls, and wonder how they get the ends to roll up - again - unless they welded the ends and re-rolled was all that I could imagine. And then with the way that you worded your text - it sounded like maybe it was possible to have rad ends all the way - pre-weld, so I just couldn't contain my curiosity, and had'ta ask.
    Again - I wasn't challenging you in any way.
    Think Snow Eh!
    Ox
  11. #9
    Jun 2014
    New Jersey
    377
    398
    203
    I thought along the same lines as MUD, get some tubing, machine inner and outer to spec, then part off.
  12. #10
    Aug 2009
    Oakland, CA
    403
    199
    I've bought lots of rolled rings from Midwest Metal --> Midwest Metal Products - Angle Rings > Custom Rolling and Bending
  13. #11
    Feb 2014
    WI
    27
    19
    Pm is fine.
    Thks
    Tried sending you a PM but your inbox is full. We can make these parts for you without an issue send me a message with some contact information I’ll I’ll get back to you right away.
  14. #12
    Apr 2012
    AR, USA
    1,031
    21
    189
    We made a one-off almost exactly like this not long ago to repair a machine. We rolled it, welded it together, and then rerolled it to get it pretty round. I think it was around .25"x2.5"x14". I'll shoot you a PM but I'd definitely investigate using tubing as well.
  15. Likes Ox liked this post
  16. #13
    Apr 2018
    8,211
    4008
    Not for steel but for future reference, in parts like these out of aluminum, brass, bronze, etc - big tubing or weldments - centrifugal castings are great. Way cheaper and good quality, roundness, density, all that stuff.
  17. #14
    Aug 2002
    West Unity, Ohio
    27,543
    7891
    9660
    Quote Originally Posted by EmanuelGoldstein View Post
    Steel Industries in the greater Detroit area forges rings like these in steel.
    Think Snow Eh!
    Ox
  18. #15
    Apr 2018
    8,211
    4008
    Yeah, there's a bunch of places up by Liaoning that do this too .... it's an interesting process. Slewing bearings commonly use them.
    Just wanted to alert people who had not heard of it that centrifugal cast tube is a viable alternative in non-ferrous. And it's not that exotic, there was even a place in the bay area doing it, pretty cheap and good.
  19. #16
    Feb 2005
    Fishersville VA
    1,821
    8
    84
    Let me catch up......
    Ox , we are good
    Jeffk....only had 12 messages in folder, maybe that's the limit?? PM sent top you
    Good suggestion from others,, Thks
    Do not need perfect rings, but cant have 6" of flat either....LOL
  20. Likes Ox, digger doug liked this post
