I am looking to have six acrylic blocks made; they will be mounting brackets for glass slab artwork. The renderings below are of a 30" long piece of similar design.
Overall size each is 19.5"x2"x1.5" (not 30" like in the rendering). That typically means starting with a rectangular cast acrylic block; cast acrylic being easier to machine than extruded, as I've learned. I can ship the acrylic to your location if necessary. A PDF drawing of the desired uniform cross-section is attached.
Three holes need to be drilled (no need for threading) in each piece, as I plan to use standard drywall anchors and screws w/washers to attach the mounts to the wall. Holes should be in the middle, and 2" from each end.
I'd need them delivered to California in about 2 weeks (end of November). I will get precise dates shortly.
Any questions, comments, or quotes can be sent to me at markjstock (at) gmail or posted on this thread, or via messaging on this site. Thank you.
View attachment WallMountXSection_v4.pdf
