Hey there, I hope these diagrams are good enough, i need 100 pieces of these to start, let me know if you have any questions. 6061 aluminum. Canada would be highly preferable, although I am open to USA quotes, I can drive it across the border near Vancouver but duties may make it much better to get the supplies from Canada.
The depth of the small hole is only around .1”, the 59/64 drilled hole goes all the way to the end allowing about 0.1” of depth for that hole. The bottom of the hole can just be tapered as per the drill bit, no need to flat bottom it, the drill I used was 118 degrees which I imagine is standard.
If you are able to anodize, please include that. I am looking for a matte/semi gloss finish.
