RFQ small 6061 part, 100 pieces
Likes Likes:  0
Results 1 to 6 of 6
    Mar 2019
    CANADA
    British Columbia
    8
    Default RFQ small 6061 part, 100 pieces
    Hey there, I hope these diagrams are good enough, i need 100 pieces of these to start, let me know if you have any questions. 6061 aluminum. Canada would be highly preferable, although I am open to USA quotes, I can drive it across the border near Vancouver but duties may make it much better to get the supplies from Canada.
    The depth of the small hole is only around .1”, the 59/64 drilled hole goes all the way to the end allowing about 0.1” of depth for that hole. The bottom of the hole can just be tapered as per the drill bit, no need to flat bottom it, the drill I used was 118 degrees which I imagine is standard.
    If you are able to anodize, please include that. I am looking for a matte/semi gloss finish.
    Attached Thumbnails Attached Thumbnails dd270144-f2f9-472b-83c1-bc8c61a9608a.jpg
    Apr 2005
    Beaverdam, Virginia
    9,089
    1137
    4606
    I figure plenty of Canadian guys will quote this so I won't bother. For the record people are going to want to know if they can quote without anodizing.
    Mar 2019
    CANADA
    British Columbia
    8
    I was going to get them anodized locally, but yes If you can anodize them also that would be good! I do not want a highly polished anodize, maybe a semi gloss type finish.
    Apr 2005
    Beaverdam, Virginia
    9,089
    1137
    4606
    Quote Originally Posted by Grimalkin View Post
    Like I said, not quoting, but I was thinking the other way around. With your picture you were expecting a quote for a part with anodize of which if you are where I am at and can't do it in house you are eliminated. Minimum price for type III is $287.50, that is insane.
    Mar 2019
    CANADA
    British Columbia
    8
    Quote Originally Posted by Dualkit View Post
    I can get the powder coat or anodize locally, but If you are able, please provide a quote with and without the finish. By no means are you eliminated by giving raw aluminum.
    Mar 2019
    CANADA
    British Columbia
    8
    This RFQ is closed, thanks.
