RFQ: Small milled Delrin blocks
Chris Attebery
Cast Iron
Jun 14, 2002
Gilroy, CA, USA
Hello,
I have a side business with a few products. My day job is getting busier and I just don't have as much time for machining as I used to. I have a couple product that will need parts soon. Most of my parts are aimed at the High Power rocketry hobby. They are all 2.5D. I've been making them on a CNC converted Grizzly benchtop mill using Fusion360 for design and CAM.
Here's the first piece. It's a small Delrin screw switch cover. They are .875" L x .4" L x .4" T. I start with a 6" x 16" sheet of .500 thick Delrin clamped to the table. I cut 9 x 11 parts per sheet. I cut those sheets into 9x1 strips on my bandsaw and do the back side in a soft jaw.
Front side operations.
1. Drill .125" holes .425" deep.
2. Drill .1875" holes .4" deep.
3. Drill .1875" pockets .125" deep.
4. Drill .375" 60 degree chamfer .325" deep. I use a sharp pointed 60 degree countersink.
5. Outside profile.
Back side operations.
1. Drill .3125 pockets .225" deep
2. Face off .100"
The tolerances are pretty loose +/-.005" would be fine. I just use standard drills and don't measure the hole sizes. I cut the chamfer as deep as possible without chipping the edge. You can make it .360" OD if that helps.
I'm looking for 500, 750 or 1000 pieces.
Chris
Pricing for your small Delrin switch cover
Hello,
5. Outside profile.
2. Face off .100"
Chris
Chris,please see pricing below; this is a perfect fit for CCMI
CCMI Quote: 2021-0261
Part Number:NA
Revision:NA
Description: Delrin screw switch cover
Material: 0.40" x 0.40" x 0.875" Black Delrin/Acetal
Quantity: 500; 750; 1000
Price: $3.93 ea. $3.73 ea. $3.51 ea.
Lead Time: 5-8 business days from receipt of purchase order, drawing design approval and deposit
Terms: 50% due with PO, Net 30
FOB: Geneva, NY 14456
Please Note:
CCMI is quoting a general tolerance of +/- 0.005”.
Above pricing is based on customer supplying sample or drawing - hand sketch will do
Above pricing is based on fabricating parts to print.
CCMI terms and conditions apply.
This email quote is simply an estimate, final details and costing will be confirmed at time of purchase order receipt.
Please send all Purchase Orders to [email protected]**
Thank you for the opportunity!
Anthony Lewis
p: 315.781.3270 ext 104 f: 315.781.3271
c: 585.281.2327 e: [email protected]
a: 88 Middle St Geneva, NY 14456
s: CCMI Plastics | Custom Plastic Fabrication and Thermoforming Company
I've got quite a few interested parties. I *think* I've replied by email to everyone that was interested. If you didn't get an email please let me know.
Chris
