RFQ Titanium Fabrication
Results 1 to 18 of 18
    Jul 2004
    Southeast Michigan
    6,495
    235
    1417
    Default RFQ Titanium Fabrication
    I have no clue where to go on this, or even what it should cost.
    I would like a titanium container, approximately 1/8" thick, 12" diameter, 24" tall. Think, 5 gallon bucket made of titanium.
    What kind of prices should I expect? Titanium grade can be anything that may be lying around. Dimensions are entirely flexible. If it's easier to go to a polygonal shape instead of round so it can be press braked, that's fine too. I basically just need a corrosion resistant container that is liquid tight and closed on one end.
    At a later time I will need more titanium fabrication done, but I need to dip my toes in to the market to determine what I should expect in terms of prices.
    Apr 2005
    Beaverdam, Virginia
    7,084
    544
    3245
    You probably should specify what you are looking for appearance wise. Not my area of expertise, but I would think forming a major portion of your container will be more costly than fabricating it mostly from wielding.
    Nov 2007
    marysville ohio
    9,173
    2613
    6056
    Quote Originally Posted by kustomizingkid View Post
    I'm in the camp of why Ti too...
    Did you read the post? It clearly says "corrosion resistant". Maybe he needs something to keep his sulfuric acid in.
  4. Likes Ox liked this post
    Mar 2017
    LATVIA
    270
    71
    144
    can't help with pricing, but I will give some idea about about the complexity of the work:
    not all Ti grades are equally corrosion resistant, Grade 1 and 2 is what I used for heat exchanger in sulfuric acid Al anodizing bath (4th year with zero signs of pitting, 12% acid at room temperature), Gr5 will corrode, and welding is not exactly straight forward, meaning - shielding from both sides is a must, short welds, let it cool, either extra large cup or trailing shield has to used to avoid contamination (which will lead to brittleness and cracking), that means lots of argon and $$$ for properly done welds
    I've worked with sheets of Gr1 and 2 with thickness up to 1,5mm, forming it (shearing, rolling or bending) is easier than working with stainless (Gr1 and 2 are less springy than SS) and a bit harder than mild steel, but as I stated - getting good quality welds won't be cheap, and I suspect the application will require for the product to be durable
    are you totally sure that you really do need Ti for this application?
    Jul 2006
    Hillsboro, New Hampshire
    6,812
    1613
    4735
    Consider deep drawing for your "bucket" if you wind up with a production requirement.
    Nov 2007
    marysville ohio
    9,173
    2613
    6056
    Would you rather build something from Ti or 316ss? This is also a forum ya know, for discussion. Its a pretty simple question.
    Well if he does need something to put his sulfuric acid in Ti will last a lot longer then ss.
    Jul 2004
    Southeast Michigan
    6,495
    235
    1417
    Quote Originally Posted by jz79 View Post
    In this case, titanium is for chloride/chlorine resistance at a working temperature of under 100 deg C. Specific chemical is HCl at up to "full" concentration (37.2%), but with various oxidizers present.
    I've been told that grade isn't important for chloride/chlorine resistance, but I'll double check on that.
    This will never end up being a production item.
    Proper weld technique is an absolute must, and I'd hope that anyone considering work like this where I said corrosion resistance would be knowledgeable...but that is totally on me for not specifying technique.
    I'm at this point where I should probably just do it myself, but my only working TIG welder is a trailblazer with an external HF box/pedal, and it's sort of a pain to set up. But I recognize that getting any fab shop to perform a by the book weld is damn near impossible, even though so many will claim they do.
  9. #8
    Jul 2004
    Southeast Michigan
    6,495
    235
    1417
    Eh shit...after reading a bit it's clear it's going to be grade specific.
    So nevermind guys...guess I need to buy my chemical engineer friend a couple beers so I can figure out how to proceed.
  10. Likes Ox liked this post
  11. #9
    Mar 2017
    LATVIA
    270
    71
    144
    HCl I'm not familiar with, but as far as I remember, the Cl would rule out any stainless steels
    Regarding welding Ti, the first heat exchanger I built that worked well, and I still have it, I made from 0,8mm Ti sheets, I formed the sheets like in the picture, pressed both ends of the sheets together so there would be basically no air from the other side, and then used slow pulse setting on the Tig welder to fuse weld the seam, it held and worked well before I built a larger one from gr2 tubing, but my application isn't nearly as nasty as HCl at 100C...
    I used this same method to make stainless tanks for other needs, and some of them regularly cycle between room temperature and +85C, haven't had a failure yet (knocks on wood )
    I'm not sure about the 100C, but maybe something like HDPE welded tank with a steel backing (or composite, like appropriate vinyl resin and glass fiber reinforcement) would work for this? HDPE will start to get soft at that temp, but if it resists the acid at that temperature, then it just needs structural backing to hold together, might be easier to build than the Ti tank
    pic of the construction method I used:
  12. #10
    Jul 2004
    Southeast Michigan
    6,495
    235
    1417
    PP and HDPE hold up just fine to the HCl, but once you start adding oxidizers it either starts crazing or softening. Right now I'm just using standard 5 gallon buckets at 60degC, and they work a few times.
  13. #11
    May 2011
    New Jersey
    1,808
    167
    983
    Why no go with something steel and fluidized bed coated Teflon.
  14. #12
    Jul 2004
    Southeast Michigan
    6,495
    235
    1417
    Quote Originally Posted by plastikdreams View Post
    Steel doesn’t hold up well in hcl environment, even when coated. Plus this routinely has stuff loaded in to it that could scratch it. I use a glass 5 liter beaker, but it gets scratched too. Really want to be able to clean it out with a scotchbrite pad.
  15. #13
    Aug 2002
    West Unity, Ohio
    24,871
    5091
    7675
    No, actually it is not.
    Think Snow Eh!
    Ox
  16. #14
    Feb 2009
    950
    166
    162
    That’s correct!, with OX moderating posts based on his opinion! Keep up the good work, well, or lack of actual machine work, you sure will get your post count up, certainly adding value to threads.
    Think Snow Eh!
    Ox
  17. #15
    Jun 2008
    Mississippi
    234
    9
    When you say liquid tight do you need a tip on it to be liquid tight?
  18. #16
    Sep 2013
    Michigan
    249
    89
    151
    Why can’t you use an XLPE container?
  19. #17
    Sep 2015
    Tennessee
    484
    245
    371
    That's actually not doable. I wouldn't even want to start on a project deep drawing titanium at any depth. No Quote.
  20. Likes Ox liked this post
  21. #18
    Jul 2006
    6,812
    1613
    4735
    Quote Originally Posted by Rewt View Post
    Well, yeah - not doable for you or me. But it's certainly doable for companies who know what they're doing:
    Deep Draw Stamping Titanium
    And maybe not that hard after all:
    YouTube
