Hey all,
I'm looking for someone to help fabricate a scissor lift to be used in an underwater application.
It is to lift a 12' x 24' platform up and down 5', from underwater to just above the water.
We are looking for a hydraulic system that would use demineralized water rather than oil in case of leaks. The lift doesn't need to move quickly, if it took 60 seconds or slightly longer to move the complete distance, that's good. The total weight of the platform will not exceed 6000 lbs (it'll more likely be closer to 2000)
The lift should be stable at any height and will be in the raised position the vast majority of the time.
Also... if another type of lift seems to be a better option that you can help with, I'm all ears. it needs to be a clean system that has no exposed moving parts above the platform (otherwise I'b most likely be using a boat lift)
Many thanks,
Rick
Many thanks,
Rick
