Thorsrevenge1
- Feb 3, 2021
Hello everyone, Im new to posting, though I have stalked through the forum for years reading this and that. I run a blacksmith and fabrication shop out in colorado and I'm in need of some one off tooling that I do not have the skills or knowledge to make myself. To that end here I am hoping to find someone to take on the project.
The project is to make a set or two of some one off tooling I need. Specifically I need a tap and die set for cutting 1" 4 start threads with each individual thread being 1" 4tpi, with each start clocked 90 degrees from the last. Now not being a machinist myself I know this is not nearly enough nor precise enough information to actually get the job done. Luckily or I think it's lucky. I have examples of both the internal and external threads I needs the tools to make. As to heat treating depending on the material I do have the means to do some heat treating on more basic tool steels such as s7 or basic carbon steels. If anyone can give me a quote for the project that would be awesome. Or if you know someone who might be willing that would be helpful too.
Than you.
Than you.
