I need a unit similar to a electric motor armature but all steel. Tolerance is not critical.
I need a 1" shaft 6" long which will slide through bearings so it can spin but not a pressed fit.
Onto that shaft I need a 3"Dia 3"long steel part pressed.
The 3"dia part can be solid round bar stock with just a hole in the center, or it could be built up as thick pipe/tubing with solid ends and hole in center to press onto the shaft. If built up it must be about 3/8-1/2" thick wall.
Needs to be true, straight, and reasonably in balance. May spin about 1,500RPM rarely, 600-900rpm often.
That's it, nothing real major or critical. I need a few for prototype units I am building and later may need alot more of them.
