NautiSouth
- Oct 21, 2019
Hi Everyone,
I'm looking for a machining source that can deliver three parts finished to drawing specifications. Parts to consider are to be made from a high-carbon bearing steel, heat treated prior to finish grind. Operations to potentially include:
- rough machine
- heat treat (via directed source)
- mill
- drill
- EDM
- centerless grind
- OD profile grind
- ID grind (potentially)
- surface grind
- inspection on a percentage of the run
- optical comparator inspection
Complete 3D data and 2D dimensioned drawings are available.
Quantity: 32pcs initially. Conservative estimate of 1000pcs/yr.
Rough Dimensions: Round cylindrical parts under 2.5" long and below .800" diameter
Material Required Date: 1/15/2020
Preference given to shops in the United States. Southeastern US or Midwestern US highly preferred.
Discussions will follow agreement on terms of non-disclosure.
Terms of Payment: 1% 10/Net 30
Message me privately on this forum if you are interested.
- rough machine
- mill
- drill
- EDM
- centerless grind
- OD profile grind
- surface grind
