Squaring up box girder
Results 1 to 12 of 12
    Jul 2016
    UNITED KINGDOM
    Default Squaring up box girder
    I am more of a welding type of guy so I don't really know what the monetary cost of machining is.
    I have a 100x100x5 girder 900mm long (offcuts I have lying around). I want it milled on each to have 4 flat surfaces square to each other.
    A girder isn't too easy to ship back and forth so if there is no one on here nearby could someone could give me an idea of what a reasonable price is? That way I can work out if local companies are giving a fair price or not.
    Jul 2004
    Houston, TX USA
    30,253
    I'll asume you really mean structural square tubing
    Impractical - unless you envision very loose tolerances for flat and square
    The 5 is too thin - it will holler on every face milling pass and though "shiney" will in no way be flat due to the milling pass releasing stresses.
    If he tries some more you will have practically no wall left
    In a word, you will be disappointed and they will find they under bid the damn thing
  3. Likes digger doug liked this post
    Jul 2016
    UNITED KINGDOM
    Ah thats a fair point.
    Apr 2006
    Denmark
    426
    1217
    98
    John is right of course.
    Why don't you tell us what you need this thing for and how 'square' and 'flat' it has to be?
    I suspect there are better ways to achieve your purpose than milling.
    Just my two 'øre'!
    Regards, fusker
  6. Likes digger doug liked this post
  7. #5
    Dec 2010
    PA
    650
    185
    170
    Perhaps a big surface grinder?
  8. #6
    Aug 2015
    Illinois
    1,430
    1017
    621
    Rectangular tubing has a lot of internal stress. Removing material from one side will cause it to deform. Each time you turn it and surface another side it will move again. Chances of ever getting it straight and square are really small.
  9. Likes digger doug, fusker liked this post
  10. #7
    May 2004
    2,511
    886
    1640
    Quote Originally Posted by Illinoyance View Post
    To a machinist. To a welder it may be exactly what he needs.
  11. #8
    Jul 2016
    UNITED KINGDOM
    In this case it has to be machinist sort of square. The vague plan was machine the girders, fill with epoxy concrete and use then as the ways of a cnc milling machine or the bed of a cnc lathe.
  12. #9
    Jan 2010
    Indianapolis
    1,350
    778
    415
    If you insist, I guess you can make a silk purse of your sow's ears, but you should attempt to visit a successful attempt of this enterprise.
  13. #10
    Jul 2004
    Houston, TX USA
    30,253
    Quote Originally Posted by Rainbows View Post
    A way to get there is resequence and add necessaries
    "Rebar" crossing both ways (6 mm all thread) screwed thru tapped holes both walls and welded in c'sink outside
    Plugs/bungs for later tapped holes as needed - all in planned for locations - similarly welded
    THEN epoxy concrete
    THEN machined for flat and square
  14. #11
    Oct 2005
    16,044
    If your going to build a real C.N.C. machine, you spend real money on proper materials to build a proper machine.
    Cobbling with what you have laying around sounds like A hobby machine.
    And there is a forum for that, one that cannot
    Be listed here.
    BTW I have designed fixtures doing just what you intend, it didn't turn out good, and I redesigned
    It using different materials and techniques.
    (Eliminated machining the box tube)
    it then ended up being a economical, repeat job for my employer.
  15. #12
    May 2016
    Arizona
    206
    8
    94
    ...And if you are doing this as a hobby and trying to go the cheap route, then having machine work done for you is not going to fit in your definition of reasonable price.
  16. Likes digger doug liked this post
