Steel Bushings
Results 1 to 14 of 14
Thread: Steel Bushings
    Aug 2012
    Toronto, Canada
    10
    Question Steel Bushings
    OD = 0.435"
    ID = 0.343 +-0.001"
    Length = 1.200"
    Material - Steel, must be lead free. Preferably with a good machinability, as I will be drilling and tapping these parts in my shop.
    Tolerances - +-0.005", except for the ID which should be +-0.001".
    Machine finish. All edges deburred.
    Quotes for quantities of 100, 500, 1000.
    I have included images of the intended application for the part. Note that the part pictured here has had some hand work done to it that I am doing in my own shop. This will include drilling five evenly spaced holes and tapping for 1-72 brass screws.
    If desired, please feel free to include an additional quote which includes the drilling and tapping of these holes so that I can decide if it would be less cost effective to do these steps in my own shop.
    Larger version of drawing available if requested.
    Thank you!
    -Dan Morrison
    Oct 2005
    15,667
    Dan, that's a very nice write up, a good drawing and pictures.
    Those tapped holes, If some one was running these on a swiss, they may
    be able to put those in for you, the part would drop off complete.
    Mar 2014
    BLACK MOUNTAIN NORTH CAROLINA USA
    360
    356
    234
    Swiss for sure , should be able to make part complete under 2 min .
    Jul 2014
    Ontario, Canada
    1,039
    744
    676
    I could do sub 2 minutes in an old CNC lathe. A Swiss should be around 45 seconds or less.
    Apr 2005
    Beaverdam, Virginia
    7,470
    707
    3524
    Quote Originally Posted by RC Mech View Post
    I am not bidding as my live tooled CNC Swiss needs a chip programmed and I can't find the needed info. Anyway I seriously doubt the tooling would last too long running at 45 seconds if you could make even one. Spot, drill, tap x 5 is 15 indexes, retracts and approaches. Since you aren't bidding your comment is pretty much stabbing who ever bids in the back, the customer now thinks he should get these at $1 a piece.
  6. Likes plothoundsman, Ox, rabidchimp liked this post
    Feb 2009
    952
    174
    162
    To the OP: is this some " art piece"?
    Aug 2012
    Toronto, Canada
    10
    Well, yes... and no.
    I would say it falls somewhere between art and craft.
    If you would like to see my other works, you can visit my blog D.M. Pipes
  9. #8
    Jul 2014
    Ontario, Canada
    1,039
    744
    676
    Quote Originally Posted by Dualkit View Post
    I did bid, w/o tapped holes and came in at over $1/pc. You'll notice if you read the OP that the main objective is to get a quote for the part w/o tapped holes; with tapped holes is a supplemental quote.
    Tooling should be fine- it's whatever steel you like so long as it doesn't have a lead content.
    You're correct: the customer may only now (however erroneously) think that $1 a piece is par for the course, but only because you mentioned it.
  10. Likes digger doug liked this post
  11. #9
    Aug 2012
    Toronto, Canada
    10
    I've spent enough time on forums over the years to know that anecdotal statements do not necessarily match up with reality, hahaha.
    The part costs whatever someone is willing to make it for.
  12. Likes digger doug, Philabuster liked this post
  13. #10
    Oct 2011
    Western Nebraska USA
    177
    31
    98
    2 minute cycle time = $1 ??? You have a $30 an hour shop rate ???? Not to mention set-up/programming/book work
  14. #11
    Apr 2005
    Beaverdam, Virginia
    7,470
    707
    3524
    If somebody could make these at your magical 45 seconds a piece on a live tooled Swiss figuring 3 hours to program and set-up they could come in at $1 charging $50 an hour. Common sense tells me the op will not want to tap these himself if someone with a live tooled machine bids.
  15. Likes Ox, plothoundsman liked this post
  16. #12
    Apr 2011
    Nebraska
    1,251
    1785
    367
    Quote Originally Posted by DanMorrison View Post
    I've got to that's some beautiful workmanship.
    JMHO
    -Ron
  17. #13
    Oct 2005
    15,667
    Heysoos keeriest !
    I simply suggested to the O.P. about the option of having the holes driiled & tapped on the machine
    to make the job "better"...I figured that he did not know that was possible to do.
    Him not having to do that operation himself. If your going to send the job out to a vendor,
    might as well have them come in complete.
    In NO way did I intend to start an online bidding war, complaint fest.
  18. Likes Philabuster liked this post
  19. #14
    Aug 2012
    Toronto, Canada
    10
    Request fulfilled, thanks everyone!
