RobMcQuillen
- Feb 10, 2013
- Le Roy, NY
We are looking for a new supplier for large Mill-Turn machining of prototype 4340 steel shaft parts. Largest part out of 8" diameter x 24" long bar. These parts will require extensive milling including 3D surfacing, 5 axis drilling, large y axis milling so they will require a 5 axis mill-turn i.e. Mazak Integrex, DMG Gamma, Doosan MX, etc. We are looking for suppliers that can produce prototypes in the 3-5 quantities in 3-4 weeks. Maybe an oil type work supplier out there that is slow right now???
If you have these capabilities and would be interested in the work described above please email me at rob(at)mcquilleneng(dot)com with more information on your capabilities and equipment.
