RFQ: 3/8" Thick Steel Plates - Laser & Milling Work - Connecticut
therieldeal
Feb 16, 2016
I am looking for someone in Southern New England, who is interested in quoting a 20-30 piece production run on some steel adapter plates.
The design is proven & has been made several times in the past, so there should be no need for back and forth with design changes and whatnot. I am looking for a new local partner to machine them for me in the future.
Click here for a screen shot of the design and a photo of the finished product, to give you a general idea of the appearance & features: Shared album - Jon Riel - Google Photos
Final finish will be black zinc plating. If you have access to this, great! Please quote the plating as a separate line item. If not, that is OK too.
Here are some preliminary details:
  • 3/8" Thick plate steel, mill scale removed, overall dims approximately 15" x 15"
  • Inside & outside profiles to be cut via Laser (or HD Plasma) & deburred.
  • Holes/features to be milled/drilled/reamed/tapped etc. on a CNC mill.
  • Location tolerance on milled features is +/- 0.003" true position.
  • All features can be milled from one side of the plate.
If interested please PM me with your location & email address, and I will send you the drawing/model to quote from. For now I'd like to keep this to local offers, but I may open it up in the future if needed.
