Eccentroid
- Sep 23, 2015
Right now, I'm in a situation. I need my stainless parts to be hard so that thet dont gall/cold weld. I can machine each pair of mating parts out of 17-4 stainless, but I must attach them by threads or a hot/cold fit, which is more expensive and less durable than TIG welding. I would have another option if one of you guys/gals could give me a case hardening/nitriding/kolsterizing recipe. This way I could weld and machine it all out of 304SS, then harden the surface. I care only a little bit about corrosion resistance; these parts are only used with sugars and an occasional citric acid passivation that gets down to 2.3PH. Thank You!
Sent from my SM-G900V using Tapatalk
