Tapered flanged tube section
essbend
Dec 3, 2020
Hello,
I am a new member, but I've gotten a lot of info from reading these forums before.
I need a part manufactured (see link) but only in small quantities initially (hundreds) before going into larger-scale manufacturing depending on demand for the end product.
I assume the conventional way to manufacture the part would be to stamp it from flat sheet. Is that correct? But I was wondering if it would be practical to form the part out of tube stock. Could a die be made to form the taper and flange out of a section of ERW?
Steve
flangedtube.pdf - Google Drive
This would be straightforward to machine from round bar or DOM tube. Seems wasteful but a CNC lathe would make quick work of it.
Stamping/drawing from flat might work, but would be hard to be cost-effective for 100's. 1000's, maybe. It's a tough draw, thick walls and tight radii and all. It would be a progressive die situation, I don't think you could 1-hit this.
Ida Know about forming from tube. There's a lot of material needs to flow out to make the flange.
Regards.
Mike
I don't need the angle that accurate. That's just the nominal taper of the mating part.
If it's turned on a lathe, I do not need such a thin wall.
I looked this over briefly and it looks like something I can do on my screw machines. Mine top out at 1.625" O.D. but I think I can loosen the collet and grab what is called out here.
I am too busy to do this right now. Tool charges would cost a bit, but this part would run mostly unattended. I will pm you my info. if your numbers come up and my schedule frees up we can work something out.
If interested to have a quote now or in the future for a progressive die to stamp the part feel free to message me. We are a small shop located in Franklin park, IL capable of all types of dies.
