snowman
- Jul 31, 2004
- Southeast Michigan
Really simple:
I need a thick washer...easiest way to describe it.
~1.61" OD, 1/2" hole through center, 3/4" thick
One side needs to be faced (purely cosmetic)
Tolerances are as follows:
1.61 ==> +/- .005
1/2 ==> + .005, -.000 (needs to slide over 1/2" rod for welding)
3/4" ==> +/- .050
Material is any steel that is weldable
Quantity, first run 20, later?? Never more than 100 at a time. Expected delivery...3 weeks
Next washer:
1.25" OD (Cold roll bar tolerances are fine)
1/2" bore (same tolerances as above)
3/4" thick (same tolerances as above)
Both sides faced
Need a small counterbore on one face, approx .1" deep, .84" in diameter
qty, terms, materials, etc...same as above
Just a small shop trying to decide if it's worth my time to do the jobs or not.
I am in SE Michigan.
1.61 ==> +/- .005
3/4" ==> +/- .050
Next washer:
Both sides faced
