Wouldn't it be easier if someone got a bull horn, went out in front of the crowd and yelled 'go home you ass holes". Seems like it would be a more direct approach.
No-Skid-Steer-Stu
Meah... closing days of War Two, Dad had unwittingly entered a Nazi slave labour compound. Big one. Some of the guards had already scarpered - officers and NCOS. The rest - enlisted ranks - readily surrendered.
The inmates were seriously emaciated, given Weird Adolf's "plan" was to work them to death in a stage of step-functions. They had calculated this s**t .. vetted it, then applied it "scientifically" on a grand scale.
Enough of the prisoners still had energy left to swarm him.... for any food he might have.
His jeep driver was sent-off for help.
The "bullhorn"?
His platoon roaring in, first deuce and half
in reverse!
Tailgate drops, belt-fed thirty cal opens up with a long burst. Over their heads. Control was re-established. At once.
There's your "bullhorn", Stuart. These folk were "friendlies", after all.
The business of getting them fed began. Earliest days, no one KNEW how fragile the human digestive system becomes under scientifically planned slow starvation. Nor that it had to be brought BACK in stages. Slow ones. PAINFULLY slow, even. Survivors have written about it. Primitive, learn what works as-you-go, but couldn't be helped.
The Allies were simply not prepared for what was found. At all.
At first the survivors were literally being killed by kindness. From food they could not manage to process.
When NOT "friendlies"? And you know in advance a riot is to be
put-down?
Advance into it centers on a vehicle ... with razor-wire at the bow. Kinda discourages climbing-on?
Sharpshooters take out anyone who even LOOKS like a "ringleader" or even cheerleader. Kill shots. Not wounding.
No need of warning. You want the opposite.
Just waste them. Fast.
Panic is your "bullhorn".
The riot turns into a rout.
Kent State would have had fewer dead or injured if the unit had proper training and had done what they are supposed to do "at once", not after f**king around and giving up the advantage.
Tactics have changed. So now they
fail to establish control.
Could was we shall have to go back to what JF works?
