1,000 KV Generator arrived today
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Jun 2006
    Kansas
    1,387
    244
    495
    Default 1,000 KV Generator arrived today
    My friend with the local crane service had a large generator that had been damaged. Someone ran into the radiator shroud, almost ripping it off.
    He brought it to my shop for me to repair.
    Sent from my iPad using Tapatalk
  2. Likes Ray Behner, JHOLLAND1 liked this post
  3. #2
    Jun 2006
    Kansas
    1,387
    244
    495
    Another photo.
  4. Likes JHOLLAND1 liked this post
  5. #3
    Apr 2004
    Modesto, CA USA
    6,985
    1175
    Red face
    I guess this answers the thread about if you deliver from your shop.
    Bill D
  6. #4
    Jan 2002
    West Coast, USA
    7,708
    478
    5171
    The 1000 KV sure caught my eye. KVA?
  7. Likes neilho liked this post
  8. #5
    Jun 2006
    Kansas
    1,387
    244
    495
    Quote Originally Posted by PeteM View Post
    Help me out I don’t know the difference???
  9. #6
    Dec 2003
    Washington
    4,713
    2223
    4057
    Quote Originally Posted by true temper View Post
    1000 KV = 1 million Volts
    1000 KVA = X Volts @ Y Amps where X x Y = 1 million (single phase)
    or . . .
    1000 KVA = X Volts @ Y Amps x 3^0.5 where X x Y x 3^.5 = 1 million (3-phase)
    The generator pictured is likely a 3 phase unit with 480V output so at 1000KVA it should be able to feed a ~1200 Amp load
  10. #7
    Mar 2011
    SWITZERLAND
    1,006
    122
    413
    The unit is not Amps but Ampère after the French mathematician, physicist, chemist, and philosopher André-Marie Ampère, 1775–1836. Plural is still Ampère, no s.
    Volt goes back to the Italian count Alessandro Volta, 1745–1827. Two Volt, no s. Kilo stems from Greek kilos meaning thousand and is written with a minuscule. So we note kVA. Or kW. Please not voltage but tension. We don’t say trumpage, do we?
    V × A = W (U × I = P, Unit times Intensity equals Power), after the Scott James Watt, 1736–1819. Plural is Watt, no s. To round this off, impedance is given in Ω, Omega, or Ohm after the German physicist Georg Simon Ohm, 1789–1845. 470 Ohm, no s. A little respect for names.
  11. Likes magneticanomaly liked this post
  12. #8
    Langley, B.C.
    1,702
    352
    995
    Quote Originally Posted by Mechanola View Post
    ...A little respect for names...
    While what you say may be technically true the term in common usage in North America is amp and amps...
  13. Likes digger doug liked this post
  14. #9
    Mar 2011
    SWITZERLAND
    1,006
    122
    413
    Sloppy language, sloppy thinking, what I was aiming at. Isn’t already the topic title out of phase? 1,000 kV, I thought, what?! A million Volt, nowhere in the world is that a transmission tension. And again, amp and amps as you write, should be Amp. Good grief, don’t defend mistakes.
    Now I wish everybody a pleasant Sagittarius time. I’m off for a month or two.
  15. #10
    Aug 2012
    California, Central Coast
    3,739
    2193
    1472
    Learn something new every day I never knew electricity was like sheep... but I dont know if I am thinking its like one sheep or a flock of sheep??
  16. #11
    May 2012
    Pittsford, NY
    1,036
    714
    667
    I am more interested in the story about what happened to the sheet metal on the end.
  17. #12
    Jun 2006
    Kansas
    1,387
    244
    495
    Quote Originally Posted by wheels17 View Post
    A guy in the storage yard was carrying a big square bale of hay with a track skid steer loader. Things were pretty tight and couldn’t see ahead of him, he was watching the ground, not knowing the hood stuck out.
  18. #13
    Oct 2005
    15,557
    Quote Originally Posted by motion guru View Post
    or . . .
    Or it could be called 1 megawatt or 1 meg for short.
    Cute leetle bugger BTW.
  19. #14
    Jun 2006
    Kansas
    1,387
    244
    495
    Tag on generator
  20. #15
    Langley, B.C.
    1,702
    352
    995
    A buddy of mine repaired/rebuilt the enclosure of a similar but smaller generator--250 KW--a few years
    ago. It was installed at mine site bout 7000 ft. up in the mountains of Central B.C. Engineers designed a
    metal framed, open sided building to keep rain and snow off. Because of the elevation the area can
    receive 15-20 ft. of snow over the course of a winter and the local crews on site told the engineers they
    didn't think the shelter was strong enough. Engineers disagreed so the shelter was left as is.
    Because of the snowfall the camp was shut down in late December and no one ventured up there till some
    time in May when enough snow had melted off to make the roads passable. Sure enough the shelter had
    collapsed on the generator, crushing a good part of the enclosure. He was working on site as an electrician
    but did side work on his off days so it made a nice little project for him...
  21. #16
    Dec 2003
    Washington
    4,713
    2223
    4057
    We are a Siemens Technology Solutions Partner and I just did a skim of the 20,000+ some odd pages of technical documentation related to Simatic, Simotion, Sinumerik, Simocrane products - (the wonder of computers) . . . not one mention of Ampere or Volta in the bunch. Many mentions of Amps (more often amps), and Volts / volts. Your observation of proper names and attribution is great in theory but abysmal in practice.
    Language continues to change, roots of words forgotten, and time marches on. Not a mistake, no disrespect intended . . . it has and will continue to devolve with people depending more and more on jet-skiing over information with Google rather than doing a deep dive into a good book. In this case, I think you jumped the shark with this observation.
    BTW - I spent quite a bit of time in my early engineering career working near Wildegg Switzerland . . . I was a Field Engineer for a TBM boring the Bözberg Tunnels and as I recall we fed the machine with a pair of 2000 kVA transformers. Beautiful country.
  22. Likes m16ty, triumph406, JHOLLAND1 liked this post
  23. #17
    Dec 2012
    Se Ma USA
    1,534
    117
    855
    Switzerland is one of our favorite countries to visit. We flew into Frankfurt, 2 hours to a hotel for a nap and left the next morning for Lauterbrunnen in the Alps for 4 nights, Italy 4 nights, back to Beckinried on Lake Luzern for 3 nights, Frankfurt, home. BMW M4 to fly on the autobahn, hit 180 KPH. All the trash I found on all of the places we went would not fill a large paper coffee cup. Including butts. Stetson pass on the way to St Gottard Pass.
  24. Likes motion guru liked this post
  25. #18
    Aug 2005
    Tucson AZ
    6,370
    9592
    3002
    I cannot agree. Language needs to mean something and should be repeatable. For example take the term "first responder". The so called journalists and media have bastardized it to no meaning. Not sure of your age but if anywhere close to mine and living in your area you should know the difference too. This just a taste of the deterioration of our language. At this rate in a hundred years English speaking people will need a Rosetta stone to read these forums.
  26. #19
    Mar 2006
    Washington
    864
    103
    56
    Quote Originally Posted by tdmidget View Post
    I cannot agree. Language needs to mean something and should be repeatable. Foe example take the term "first responder". The so called journalists and media have bastardized it to no meaning. Not sure of your age but if anywhere close to mine and living in your area you should know the difference too. This just a taste of the deterioration of our language. At this rate in a hundred years English speaking people will need a Rosetta stone to read these forums.
    Survival of the fittest, language is no exception to evolution. I would have been beaten by a nun for saying that in school, but hey, we’re evolving.
  27. #20
    Aug 2005
    Tucson AZ
    6,370
    9592
    3002
    Yes, WE are evolving but Egyptian hieroglyphics have had more durability than English in the past 50 years. You could have pointed out to Sister Whatever that without the durability of Greek and Latin and Egyptian languages she would not have a job.
