I realize there is not a straightforward theoretical answer, but I'm hoping someone here might have experience with the same lift. I have an 1988 Clark C500Y150 in good condition (rated 15,000 lb @ 24" from fork face and 101" in the air) and I'm considering purchasing a machine that is 103" x 75" and 13,500 lbs. So assuming that the center of gravity of the machine is in the center (worst case) that puts the load center at 37.5" from the fork face after moving it to the edge. Some basic statics says this would be overloaded, but what factor of safety is built into the rating? I only need to lift the machine off a flat bed and drive it down my driveway.
Does anyone have any experience with the same lift? I'm told it's very conservatively rated but I've not had it long enough to get a feel for it's limits.
