20" bandsaw upright in F150 pickup
Results 1 to 19 of 19
    Apr 2004
    Modesto, CA USA
    5,768
    859
    Default 20" bandsaw upright in F150 pickup
    I am looking*at buying a powermatic metal/wood bandsaw which will weighh about 1200 poounds. a little over six feet tall. can it be hauled upright in the back of a f150 pickup. or is it too tall and the center of gravity will make the trcuk to tippy for freeway speeds. I do not like the newer trucks that jacked up the whole truck to make it look tougher. It raise the CofG several inches over the older designs for no reason except to make bed access harder.
    I will remove the table. I bet the upper wheel could come off if needed as well.
    Bill D.
    Dec 2008
    New York
    8,546
    2276
    Quote Originally Posted by Bill D View Post
    Bill D.
    most machines are bolted down to a big heavy duty wood pallet. sometimes binding nylon straps are used the ones you tighten with ratchet mechanism they are rated in tons the bigger ones. pallets are often made from big wood timbers bolted together
    Oct 2017
    CANADA
    Alberta
    Strap it down , drive slow, know your limitations
  4. Likes kev74 liked this post
    Aug 2015
    Illinois
    861
    712
    367
    I would suggest renting a drop deck trailer. It will save a lot of work in the move and there will be no question of the high CG messing up the truck handling.
  6. Likes swatkins, BobRenz liked this post
  7. #5
    Apr 2007
    Morgantown, WV
    807
    251
    318
    I agree with Illinoyance rent a trailer for a day. The biggest problem I see is that there is nothing substantial on an F150 to tie it to, I mean to really strap it down.
  8. #6
    Jan 2017
    Oregon
    1,057
    210
    786
    My F-150 has 4 tie-down points that are pretty damn secure.
    I transported my vertical band saw in the bed with 4 ratchet straps and lived to tell the tale.
    Wasn't scary at all.
  9. Likes Ray Behner, tdmidget, WHHJR liked this post
  10. #7
    Mar 2009
    Brunswick Oh USA
    4,268
    4345
    2502
    Quote Originally Posted by jancollc View Post
    Yup, same thing with a 20" Delta.
  11. Likes WHHJR liked this post
  12. #8
    Oct 2017
    166
    43
    48
    I've transported an 1800 pound load in my little T100 where the center of mass was about the top of the bed, and it didn't feel sketchy at all. I took turns slow and never sped though. I always have a massively overbuilt (not heavy, so maybe overengineered is a better term) lumber rack I can very securely tie things to.
  13. #9
    Jun 2009
    Near:Louisville, KY
    1,665
    129
    365
    Try a Moore #2. It is not only possible, but it's a better thrill than a roller coaster.
    Good tie straps or chain and binders along with sensible driving and it will work. Stop a few times and check your load.
  14. #10
    Aug 2003
    New York
    121
    6
    25
    I transported a 1964 V ram J head BP in the back of an old D 250 Dodge PU. Framed base in with 2 x 4's so it couldn't slide around and tied off to eye-bolts in the bed rail. Removed head and ram for transport. Drove from Camden, NJ to Albany, NY (235 miles) with no issues. Drive careful, pay attention, and you'll be fine.
  15. #11
    Jan 2002
    West Coast, USA
    7,307
    358
    4250
    Block the base so it can't skitter about. Just straps and ropes holding it to the bed aren't enough.
  16. #12
    Aug 2007
    GA
    582
    96
    Should be fine but put a tiedown from the hitch, over the tailgate, to the saw, then hook in with multiple tiedowns along the bed sides, not just in the stake hole tops as the hooks will pull the sheet metal up around the holes- you need to get the hooks down inside the stake holes and/or use cleats in the bed if you have them. 2 tie downs per side, not one going across.. Tie the wheel doors and motor doors closed.
  17. #13
    Oct 2005
    10,275
    17342
    5361
    Here's Bill.....Saw sticking up like Lady Liberty in the back of the f-150,
    tooling down the freeway:...
    Eagles - 'Ol' 55' (lyrics in description) - YouTube
    "Cars are all passing me, trucks are all flashing me"
  18. #14
    Sep 2016
    Missouri
    259
    106
    55
    By design bandsaws are column loaded heavier on the one side . They tip easier in the direction that has the saw frame, I have a do all saw with the skid the same width as the base. when I lift it with both forks spread as wide as the base and lift. it almost wants to tip to the heavy side. Use a wide skid and bolt the saw down good in the center and spread the forks out as wide as possible.
    The weight is distributed off center.
  19. #15
    Jul 2009
    Peoria, IL
    11,055
    41
    8342
    Hmm. I recently hauled a 6x18 surface grinder and an Amada HA250 automatic bandsaw with outfeed table in an F-250. All the way to Texas. No issues.
  20. #16
    Mar 2009
    4,287
    81
    722
    How many miles of travel? You are over the 1/2 ton limit. It will also be no fun when unloading.
    I never exceeded 500-600 pounds in the bed. Drop trailer would be easier.
  21. #17
    Oct 2017
    166
    43
    48
    Quote Originally Posted by rons View Post
    Isn't the half ton rating more a class than an actual specification? Stay under your GVWR and GAWR and you will be fine. Most reasonably modern half ton pickups can handle much more than a half ton.
  22. #18
    Apr 2004
    Modesto, CA USA
    5,768
    859
    A little under 400 miles, 3000' up and down. Two of those passes are known worldwide for the windmills installed there due to strong winds.
    Ford has not rated a truck in tons after the Model A was replaced by more modern designs. The current F150 is rated for about 1400 pounds of payload.
    Bill D
  23. #19
    Jul 2009
    Peoria, IL
    11,055
    41
    8342
    I've had 3000 lbs in the bed of my F-250. Unfortunately, the cross members under the box have rotted. She loses a few pounds every time I load it.
