Abused nylon straps, any way to shorten and re-use, or just save hooks, toss strap? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Oct 2017
    611
    164
    173
    Quote Originally Posted by Tyrone Shoelaces View Post
    In the UK lifting gear is inspected by representatives of your insurance company every 6 months. I've accompanied the rep on his rounds at several shops. Any slings like that would be scrapped immediately. No ifs, buts, or maybes. The guy would watch me cut them in half on the bandsaw. They were draconian on this issue.
    Overhead crane structures and the wire ropes were also rigorously inspected every 12 months.
    Regards Tyrone
    It isn't sketchy cutting something fibrous on a bandsaw?
  2. #22
    Apr 2006
    Manchester, England
    8,920
    1420
    5873
    Quote Originally Posted by Strostkovy View Post
    Yeah, it can be a bit snatchy at times but I've still got all ten fingers. Like any machining process you've got to be on your guard.
    Regards Tyrone.
  3. #23
    Oct 2011
    West-Central Illinois, USA
    1,315
    2102
    602
    Last I knew hook straps were for hook to load pull (like “snatch em straps”) or basket only. In fact, I don’t like to choke anything if it’s heavy enough to hurt my foot if it failed. Better to get more than one strap & try to handle the load.
    Good luck,
    Matt
  4. #24
    Mar 2011
    Denver, CO USA
    10,214
    58
    5698
    Clamped between some wood.
    Gooped with hot melt
  5. #25
    May 2016
    Tennessee
    506
    68
    242
    Regards Tyrone
    Wow. Not that it’s a bad idea, but sounds expensive to have a guy to go around to every place with lifting gear to inspect.
    We just do in-house periodic inspections and inspect before each use.
  6. #26
    Oct 2011
    1,315
    2102
    602
    Oh-Ohhh, your insurance is gonna have a clause that makes you swear you are following all regulatory policy. When you dig in those weeds there is a time interval for a lot of things. Your chains, ropes & lifting devices are regulated...
    Good luck,
    Matt
  7. Likes tdmidget liked this post
  8. #27
    Apr 2006
    Manchester, England
    8,920
    1420
    5873
    Quote Originally Posted by m16ty View Post
    The company I was working for at the time had about 100 employees but we did lots of lifting of heavy components. We had lots of chain slings as well as wire ropes and the more modern soft slings. The inspector visually inspected every link on every chain, he once found a damaged load bearing link on a 10 ton chain block ( fall ) that some fool had cut half way through with an oxy-acetylene torch. Whoever did that either didn't notice what they'd done or never said anything !
    On the 6 monthly lifting gear inspection visits he'd be there for about 3 days. On the visits that incorporated the overhead cranes he'd be there for about 5 days. 10 overhead cranes ranging from 3 tons to 40 tons.
    How much it cost I don't know, I suppose it would be in your insurance premium.
    I once worked with the rep when the people I worked for had changed insurers. What a performance that was, every lifting beam had to be measured and the sizes noted down. Every piece of lifting gear had to have all it's details noted down. This place employed about 3000 people so you can imagine how long it took. I was an apprentice at the time and basically I was there to " foot " his ladders. That was a really boring month.
    Regards Tyrone.
  9. #28
    May 2009
    Wyoming
    3,477
    8614
    5651
    ...The inspector visually inspected every link on every chain, he once found a damaged load bearing link on a 10 ton chain block ( fall ) that some fool had cut half way through with an oxy-acetylene torch. Whoever did that either didn't notice what they'd done or never said anything !
    That inspector saved somebody's life, I hope somebody thanked him.
  10. #29
    Apr 2012
    New Zealand
    714
    175
    200
    Quote Originally Posted by Oldwrench View Post
    The inspector did his job.
    Cleansing with fire is appropriate for any suspect strops- so inexpensive for the work they do.
  11. #30
    Apr 2006
    Manchester, England
    8,920
    1420
    5873
    When the first modern soft slings came out over here in the early 1970's the salesman used to ration them. You might order 10 and he'd give you 4 if you were really lucky !
    Regards Tyrone.
  12. #31
    Mar 2007
    England UK
    1,907
    789
    777
    We inspect stuff on site weekly but all accessories still get a 6 month thorough inspection. Just had the guy round last week.
    U.K. Lifting regulations require:
    Lifting attachments - every 6 mths
    Lifting equipment - every 12 mths (or every 6 mths if they are to be used for lifting people).
    Some things like pallet trucks are excluded from the regs.
