atomic pallet jack
Results 1 to 4 of 4
    Oct 2005
    western washington state
    3,471
    2157
    3372
    Default atomic pallet jack
    12 months ago USS Nimitz ---CVN 68--entered maintenance withdrawal from service at naval base Kitsap--a few miles to my north
    the pallet jack pictured here was removed from Nimitz ordnance service
    it incorporates bespoke build features typically found in military material handling assets--builder of this unit---Wesley International of Georgia
    --specifics of this implement include:
    derating from 10,000 lb non-mil to 6000 lb mil spec
    frame thickness of 0.325 in 8 inch c-channel hot rolled alloy
    walking beam forward bogies--3 inch diameter urethane load rollers
    tie down weldments on A frame
    empty service weight about twice non-mil counterpart
    I buy these units to chop--tines are adapted for fork extensions
    which serve my needs better than longer forks in tight aisles/shipping containers
    Attached Thumbnails Attached Thumbnails 100_2501.jpg   100_2503.jpg   100_2505.jpg   100_2507.jpg   100_2508.jpg
  2. Likes DrHook, TeachMePlease liked this post
  3. #2
    Oct 2005
    3,471
    2157
    3372
    walking beam construct is meaningful when duty application is over non-skid plating, carrier decks, rolling blue water,
    Attached Thumbnails Attached Thumbnails 100_2511.jpg   100_2512.jpg   100_2513.jpg   100_2514.jpg
  4. Likes DrHook liked this post
  5. #3
    Oct 2005
    3,471
    2157
    3372
    for comparison--BT pallet jack components of 6000 lb unit
    plate thickness 4mm
    load roller 82 mm single
    BT is swedish builder of exceptional quality--acquired by Toyota in 2000
    chopped BT forks are my go to extensions--light, unbendable swedish steel
  6. Likes DrHook liked this post
  7. #4
    Aug 2012
    California, Central Coast
    2,859
    2095
    1059
    I gave my neighbor a toyota pallet jack to convert into a 3 point fork attachment for the back of his tractor. It was like you said, made in sweeden.
  8. Likes JHOLLAND1 liked this post
