Can Vidmar cabinets be safely moved full of stuff?
Results 1 to 7 of 7
    Jul 2021
    Idaho
    10
    5
    Default Can Vidmar cabinets be safely moved full of stuff?
    Some years back I bought several Vidmar cabinets made to be mounted in a vehicle. They're similar to the normal Vidmar offerings--60" tall, roughly 30" wide and 30" deep, but they have drawer locks that keep them from rolling open when you go around a curve. None of the drawers have more than 100 lb of stuff. Most have maybe 50 pounds and I recall they're rated for 400 lb per drawer. These are 9-drawer cabinets, btw, so let's guess the total weight of stuff in each cabinet is 500#.
    Question for someone with experience in these matters: Can these Vidmar cabinet frames be pallet jacked/forklifted without damage while leaving the drawers in?
    Sep 2010
    Guinea-Bissau, West Africa
    808
    140
    Quote Originally Posted by Borealis View Post
    I've done it, but used pinch bars to lift them so that the forks are going under the legs of the cabinet that are normally in contact with the floor (because that point is obviously designed to support the load). Never wanted to try by lifting in between the legs when loaded. The way I do it, it doesn't bend any sheet metal.
  3. Likes JoeE. liked this post
    Aug 2004
    Virginia
    2,911
    236
    1359
    I picked mine up with a skid steer and moved it across the shop full. No problem if you go really slow and don't hit any bumps. Like Mr. Atkins said, make darn sure you pick it up from under the rails.
  5. Likes Laurentian liked this post
  6. #4
    Sep 2005
    Oakland, CA
    3,042
    612
    986
    Ours are up on blocks so we can get under them with a pallet jack and we pick them up under the rails, but we have moved them with a forklift between the rails with no issues. If your drawers are heavily loaded, the shell can and does rock and twist a bit regardless of how they are picked up, but just be aware and go slow.
  7. #5
    Jul 2021
    Idaho
    10
    5
    Roger. Thanks for all the replies. We'll pick 'em from under the rails and go slow.
  8. #6
    Sep 2005
    Northern California
    1,126
    189
    I have lista, Kennedy and a canadian equiv (rosseau) all with fork lift bases And have moved all full several times. But that said theyve alwas gone in the truck with the drawrers up againt the trailer box. The latchwork for the drawres is a bit sketchy when a 30" drawrere is full of Cat40's
    When lifting they're on wood stickers with the top tied off to the mast of the lift truck,
  9. Likes Laurentian liked this post
  10. #7
    Sep 2005
    Oakland, CA
    3,042
    612
    986
    Stretch wrap on the drawers works too. If you are going to truck them full, stretch wrap them to each other or strap them to keep them from twisting/racking.
  11. Likes Laurentian liked this post
