Can you lift a Harbinge horizontal mill by the top bar?
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2017
    Vermont
    13
    5
    Default Can you lift a Harbinge horizontal mill by the top bar?
    I bought this Harbinge at an estate sale, and I need to lift it out of the basement through a bulkhead exit with no stairs. If I remove the spindle and slide the top bar back, can I lift it using a sling under the bar? Or will it deform, crack or bend under the weight?
    Oct 2009
    Olympia, Wa
    617
    304
    173
    I have never lifted a Hardinge that way but I have lifted a few others that are much heavier. That is generally the way to lift them as far as I know. Just get the slings close to the casting and should be fine.
    Oct 2017
    Vermont
    13
    5
    Thank you very much.
    May 2016
    Tennessee
    421
    57
    205
    Yes, you'll be fine lifting by the bar. We do it all the time.
