Caterpillar Diesel Forklift F-16 Code .. Help Please
Likes Likes:  0
Results 1 to 1 of 1
    Dec 2019
    Question Caterpillar Diesel Forklift F-16 Code .. Help Please
    2016 CAT Model DP25N s/n AT18E00337 Diesel Lift Truck
    Has a Fault code F-34 wont move on cold startup
    check & clean all wiring harness connections at VCM, ECU,etc, cleaned and tightened battery cable's & posts now it wont move when you engage the seat belt, F-16 fault code ..replaced the
    F/N/R Lever and still has same prob, next did the same on Dash Display Harness cleaned the connections at Transmission as well.same thing you hook up seat belt then it wont move.
    we have had several of these Forklifts do the same thing seems to be moisture related but ?? Located in West Texas. Please Help
