Richard/SIA
Cast Iron
- May 13, 2007
- No. Nevada
This old soft terrain Clark 6K has been a pretty good machine despite some "Deferred Maintenance" issues.
Unfortunately I got a newer CAT and traded the Clark away.
After learning how incredibly expensive a CAT is to keep running I sold it and made another trade to get the old Clark back.
Naturally the guy who had my Clark for a couple of weeks is the sort who can break an anvil without even trying.
So now I have to replace the ring gear on my flywheel as well as the starter.
Parts were not too hard to find, even found a manual.
Problem is that the procedure shown in the manual is not working for me.
Made the 11" slide hammer to partially remove the input shaft and did so.
Except that I still have a portion of the input shaft clutch spline extending into the clutch housing.
The manual cautions against removing the shaft too far.
But it seems my shaft has to be two pieces and the clutch spline is not being pulled back enough, if at all.
Access to the two lower bolts holding the throw out assembly is nearly impossible, had to ruin a wrench on the bench grinder to have any chance at all.
Manual claims that after the input shaft has been retracted the whole clutch and TO assembly come out together.
Sounds relatively simple, if it only actually worked that way.
Unless I can come up with a way to move the spline out of the way I am back to pulling the engine.
REALLY do not want to have to do that!
Suggestions for what the manual has failed to reveal or instruct will be very much appreciated.
I did look around the 'Web for an old Clark specific forum but did not see any.
The knowledge base here seems to be second to none so giving this a try.
