Crane collapse in Austin, TX
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Sep 2010
    Oklahoma City, OK
    3,308
    573
    1456
    Default Crane collapse in Austin, TX
    Looks like some of the lifting hardware wasn't properly secured or maybe just failed.
    Article-
    Falling construction crane captured on video | KXAN.com
    Video-
    Falling Crane Austin - YouTube
    Oct 2005
    10,340
    17390
    5399
    I can't understand why the shedding of the load caused the crane to fall over
    like it was overloaded.
    Unless there are (2) different problems going on here.
    When the shackle broke (or the insert pulled out, or what ever broke) the
    load fell to the ground.
  3. Likes bryan_machine liked this post
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,111
    442
    If you watch the crane at the instant the load shifts, the operator starts to boom down or it dropped uncontrolled? When the load starts to move again it seems the boom was at too low an angle.
    Steve
    Sep 2010
    Oklahoma City, OK
    3,308
    573
    1456
    K=1/2mv^2. It doesn't take a lot of velocity to generate a whole lot of force and when that rigging failed that panel was nearly in free fall for a few feet.
    To me it looked like the crane itself was fine and that an outrigger itself failed or it's footing subsided.
  6. Likes tdmidget liked this post
  7. #5
    Oct 2005
    10,340
    17390
    5399
    Quote Originally Posted by Cole2534 View Post
    I see, what your saying is the load dropped, then the rest of the rigging
    "Caught it".
    I agree that would cause the over load.
    Note how the crane is "following" the load as it hinges up, and the crane
    continues in the same "swing" direction after the overload.
    Could be the operator was really getting on the swing, either to "catch it"
    or was still in "normal mode" and was in a hurry.
  8. #6
    May 2011
    Sandy Hook, MB Canada
    899
    178
    Hello Cole2534
    Guy in yellow that was actually standing on the base of the slab when she let go got the scare of his life. Lucky to be alive. Probably had to wipe himself after that.
  9. #7
    Apr 2010
    Justin, Texas
    326
    92
    Looks to me, that when the cable or fitting failed, it momentarily unloaded the spreader, then hit it with all the load again. That was probably enough of a bounce to simply tip the crane over.
  10. Likes digger doug liked this post
  11. #8
    Jan 2014
    Temecula, Ca
    2,071
    932
    2733
    Look at the date. They were all probably hungover and making triple time.
  12. #9
    Sep 2010
    Oklahoma City, OK
    3,308
    573
    1456
    Quote Originally Posted by cvairwerks View Post
    Agreed. It was a tilt-wall panel they were erecting, so I imagine that spreader has sheaves on it to allow the panel to rotate up.
  13. #10
    Jan 2011
    BFE Nevada/San Marcos Tx
    389
    289
    172
    Southeast Austin is black gumbo clay ground, my old shop was not too far from there. More than a few times we would be in the middle of moving something with the crane and the outrigger pads would just start sinking under the pressure. I was the operator one day when the crane damn near ended up on its side, nothing scarier than watching all your rigging sliding of the deck as you walk onto the glass of the cab
  14. Likes Monarchist, boslab liked this post
  15. #11
    Mar 2007
    On Elk Mountain, West Virginia, USA
    1,952
    728
    652
    Looks to me that rather than lifting clear to rotate the slab around its horizontal axis, the operator was trying to speed thngs up by using the swing to upright the slab, at the same time. This would put a side load on the boom that would be hard to calculate. Possible that this did something to the outriggers or cribbing that predisposed the whole crane to tip.
    It does not look to me that the jerk when remaining slings caught the slab should have been enough to tip the whole crane, unless the whole pick was 'way too close to capacity. Dalmatiangirl may be on the right track
    I wonder how lifting inserts are designed or qualified. I would suppose that they would have to be welded into the reinforcing. I would not trust a simple Lewis for multidirectional load in a thin slab.
  16. #12
    Aug 2002
    West Unity, Ohio
    23,324
    3602
    6536
    Quote Originally Posted by Ciszewski View Post
    Hello Cole2534
    Must not have much experience cutting farwood. Not learned to step aside from a falling tree as opposed to trying to outrun it.
    Think Snow Eh!
    Ox
  17. Likes cyanidekid, Mark Leigh liked this post
  18. #13
    Feb 2013
    Houston TX
    3,649
    15
    1729
    The article is of kind annoying, saying that using a crawler is inherently unsafe over a tower crane.
    Never mind the fact that those tilt up panels aren't exactly light, and a tower crane would have to set them all from spot, meaning HUGE load radii.
    +1 for rigging failing and the impact loading on the crane causing the crawler to tip over.
  19. Likes digger doug liked this post
  20. #14
    Jun 2009
    Near:Louisville, KY
    1,667
    133
    366
    We have many new tilt-wall buildings here due to the UPS air hub and two busy Ford plants. Every one of them has been set with Manitowoc 3000 class cranes. I doubt a single tower crane could reach more than a few panels... This style building is built for lots of area on a single floor. Tower cranes are more useful for smaller footprints and many stories where the max loads are much smaller.
  21. Likes digger doug liked this post
  22. #15
    May 2016
    Tennessee
    306
    51
    166
    A tower crane wouldn't work well at all standing up panels.
    Rigging attachments pulling out of panels used to be fairly common, not so much in recent years. The rigging failure was more than likely due to the people that poured the panel and set the lifting attachment points.
    I've seen one and heard of many more instances of rigging attachments pulling out of panels. All the ones I've heard of, the panel just falls and breaks into pieces. I can't see what actually causes the crane to turn over. I have seen instances where the crane will turn over backwards (or at least flip the boom over backwards) when the load is released from the boom rapidly. It's due to the boom "whipping" back when the load is released suddenly.
    If the operator did boom down, instead of hoisting down, that was a pretty stupid thing to do. There is also way too many people around the load, and the one guy was actually standing on the end. I bet the parties involved really didn't plan for this video to get out.
  23. Likes digger doug, tdmidget liked this post
  24. #16
    Oct 2005
    10,340
    17390
    5399
    Think Snow Eh!
    Ox
    +1, and clearing the surrounding area of brush beforehand with said chainsaw.....
  25. #17
    Dec 2012
    AUSTRALIA
    473
    107
    The crane has way too much boom for panels.It looks like a 100ton crawler to me,and I think either a trackframe has broken,unlikely,or the ground has collapsed under it.A crawler normally pivots over the track ,and that one doesnt do that,the side just collapses......still he has way too much boom for panels.........panel rigging is set by a concrete laborer at the factory,generally a young guy who cant read,write ,or stay off ice.....So would you trust the lifting points?...Seen theb break out of kerbstones,let alone a 20 ton panel.
  26. #18
    Jan 2011
    389
    289
    172
    Quote Originally Posted by john.k View Post
    That is how black clay acts, surface can be hard as stone, 2' down its mush. The day I almost flipped crane the ground was dry, drove 20T crane into position, loaded semi pulled in alongside. Last (heaviest) piece was a pipe bender that was pushing 20 tons, initial lift was fine, then as truck pulled away the ground under outriggers started giving way, we had to use backhoe to retrieve outrigger pads, they were 3' in the ground.
  27. #19
    Dec 2012
    AUSTRALIA
    473
    107
    When youre moving a crawler,if the tracks arent sinking in,you assume the ground will be good for work......but I still think if he had a sensible boom length he would have recovered easily....the worst fright I ever had was a crane barge turning over,I was lucky not to drown.Years ago I saw a operator ride an old dragline down a slope into the river..he was still holding the levers when they pulled the crane out of the river with a D9...open cab,he just had to let go.
  28. #20
    May 2011
    899
    178
    Hello John.k
    Truck crane.
    Scroll down the page to watch the other 2 videos.
