Datson/Nissan fork lift
Results 1 to 8 of 8
    May 2011
    southern in.
    1,472
    1961
    385
    Default Datson/Nissan fork lift
    Got a small 3000 lb. fork lift that has began to stop about a foot off the floor when letting the forks down. Can't get it to go lower, but by setting for a few days, forks will slowly go down by themselves. It sounds like a hydraulic problem, but not sure where to look. Has anyone run into this before?
    JH
    Oct 2019
    NICARAGUA
    106
    41
    There is usually a restriction somewhere in the circuit so the load can not be lowered to rapidly, but allows full flow when lifting. I would look for dirt or other blockage in this restictor. Cant help with the location, sorry.
    Aug 2012
    California, Central Coast
    3,966
    2217
    1568
    I just redid the cyl seals on my datsun 5000lb. It has a center freelift cyl and two tall cylinders on either side to lift high (3 stage mast). The two tall cylinders are connected together and one of them has a flow restrictor at the bottom. You need the forks raised up to get to it, or even see it.
    If you remove it be sure to block up the mast so it can not come down.
    Dec 2012
    AUSTRALIA
    2,435
    10
    765
    It will also have hose bust protection.....required by law now,I think.......hose bust valving is usually in a block welded to the cylinder,or even in the solid base of the cylinder......now,Im not sayin you should remove it,but that is likely where your problem is ......and you are lowering too fast ,and the valve is moved by the pressure differential.
    May 2011
    southern in.
    1,472
    1961
    385
    I appreciate every ones input. I should have stated that this is a 1973 model. Would it be likely to have the hose bust protection on it? I haven't delved into the manuals very much, but have never noticed anything like that. Will have to look closely now.
    On edit: I also should have said that it only stops when it is about a foot or so above the floor. Above that it works good.
    JH
    Jan 2019
    Tennessee
    512
    160
    129
    Quote Originally Posted by James H Clark View Post
    JH
    pinched hose on the hose reels?
  7. Likes James H Clark liked this post
    Dec 2012
    AUSTRALIA
    2,435
    10
    765
    It will be a internal mechanism to stop the cylinder banging down......try lowering a lot more slowly at the bottom ,see if it still happens.........many hydraulic machines have a coil spring and plate to restrict flow as the piston nears end of stroke..........it will be inside the cylinder,so not easily removed or repaired.
  9. #8
    May 2011
    southern in.
    1,472
    1961
    385
    Again, I appreciate all the tips and suggestions, thanks to all. Haven't had the time to get into it, but will.
    JH
