Bill D
- Apr 1, 2004
- Modesto, CA USA
I saw this jib crane on craigs list. It looks like a standard wall or vertical support post mount. But it comes with an I beam vertical post welded to a base plate with gussets like a regular pole type. It only swings 180 degrees or so.
Seems like the vertical post is less critical since the bolted on hinges could be shimmed level if needed? I mean if the base settles uneven over time.
Bill D
Bill D
