Dirt floor forklift, is it possible? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
  1. #41
    Aug 2015
    Illinois
    1,526
    1133
    653
    I am put off by the repeated use of the term gravel. Gravel is rounded particles produced by natural forces. It is worthless for paving. For a stable floor the material needs to be angular particles graded from top size to dust. Ideally it would be crushed stone, commonly known as dense graded aggregate. Recycled concrete of the proper gradation is probably equivalent to crushed stone.
  2. #42
    Mar 2007
    England UK
    1,907
    789
    777
    What about mesh grid and stone or crushed concrete fill? The grid is plastic with cast-in square or hex shapes. Level and compact your ground, lay the grid, fill with material and rattle it flat with a vibro plate.
  3. #43
    Dec 2012
    AUSTRALIA
    3,258
    12
    1073
    unfortunately ,the days you could go round to the quarry and get a load of crusher dust,mixed crushed waste, for a carton of beer are gone...........now a delivery by quarry truck will cost around $500........but the stuff is ideal for yards and drives ,and will even last on considerable slopes ,provided water flow cant undercut it....I had lots of trouble with the track down my yard,was always washed into deep wheel ruts..........filled the ruts with crusher waste,and 20 years later ,its still dead level ,no more erosion,and no more slippery track in wet weather
  4. #44
    Oct 2005
    18,885
    Y'all wan't to take notice of post #39 ?
  5. #45
    Feb 2007
    Ontario, Canada
    137
    266
    18
    I used to go to a Mennonite fab shop around here, the whole place had a dirt floor but it was as hard as concrete. I asked how they did it, a guy said they compacted the dirt mixed with oil, using fork trucks (no aggregate that I could see). Like someone suggested in this post previously, it was "low cost, but high labour". All their machines were directly on the floor including a large brake press, milling machines, etc. with lots of fork truck traffic.
  6. #46
    Dec 2012
    AUSTRALIA
    3,258
    12
    1073
    Problem with dirt floors is if the soil gets saturated,as when there is weeks of heavy rain,and the water table rises......then even hard packed dirt become plastic ,and even boggy........on a hilltop,it would be OK.
  7. Likes DJ2 liked this post
  8. #47
    Oct 2004
    Iowa
    3,233
    77
    458
    Betwixt all my buildings, I started with everything from marginal concrete to dirt. Marginal, meaning 4" thick if LUCKY, and NO reinforcement. Over time, I've fought this same battle, and there's really only one machine that I can count on to get in and out of all the buildings and carry a pallet... that's my farm tractor with a light 3-point fork attachment.
    My pole barn has a foot of crushed rock, starting with a base of 4", then 3-and-down, topped with fines. I put it down in 3" lifts, using front end loader to spread, and a plate compactor to hammer it in tight. I did this because the bozo caretaker of the property chose to dig out a foot of dirt from the floor to provide enough overhead clearance to rent the space for RV storage... effectively, it became a swimming pool, and in middle of winter, that water would freeze, crushing RV wheels and tires where they sat...
    Suffice to say, that no matter how hard one packs the floor, there's only ONE time of year that I can rexpect my Hyster H50H to be able to get in and out of the building with any servitude, is during the middle of damned-cold December through February... and the reason why, is because Mother Nature provides pavement... ice... to hold it all together. Without it being frozen, the rock simply cannot compact tight enough to maintain cohesion under concentrated loads of the Hyster's small tires... it peels up just a little rock, immediately causing the forklift to lean and rock back and forth, digging divots that it cannot climb out of. Yes, small steer tires, with no load on the mast, is the worst combination.
    My Clark IT-60 has Super Singles all around, it does better, but it's too big and tall to maneuver well inside the building.
    On-grade, Four inch concrete... even reinforced... lasts about one winter, before it starts cracking up under the weight of machines. There's simply not enough cross section to allow the concrete to support concentrated weight over soil that has moisture under it... frost heaving causes the edges to lift the center, leaving it unsupported... so until the soil beneath can be isolated from moisture ingress, and prevented from freezing, it will NOT support machinery weight worth a hoot. I wish I could do my floors for $5/sqft... but no chance- they'll be twice that... plus a border foundation and drainage, foam insulation for stopping frost.
  9. #48
    Dec 2012
    Se Ma USA
    1,820
    147
    1002
    Concrete and be done with it. Doing concrete will allow you to put a vapor barrier under the slab and help keep moisture out of the building. Critters have a hard time getting through concrete to eat the wires on your stored items.
