Easiest way to move a forklift 40 miles?
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Jul 2004
    Southeast Michigan
    6,932
    276
    1757
    Default Easiest way to move a forklift 40 miles?
    Weight is 8500 lbs.
    I was going to rent a trailer and pull it behind a 4x4 F150...but lift deck trailer rating is only 7000 lbs and I'm not sure it will lift up with 8500 lbs on it.
    Roads are all country roads so it's not like I'd be doing 65 on the interstate, but it's still about 2,000 lbs over max haul weight.
    Should I be able to call the average wrecker?
    Aug 2010
    Minnesota
    2,141
    182
    1603
    I would probably tow it with an F150 but thats not exactly the best idea... a wrecker will do the job and you can wipe your hands of all liability.
    Feb 2013
    Houston TX
    3,916
    16
    2014
    Quote Originally Posted by snowman View Post
    Weight is 8500 lbs.
    A small single axle car hauler roll back didn't have any trouble with the small forklift I moved last year. Tag said it weighs about 8500lbs or so. $300 bucks for about 50 miles.
  4. Likes cyanidekid liked this post
    Sep 2009
    Phoenix,AZ
    2,028
    3216
    542
    Take lunch and road it !! LOL
  6. Likes Garwood, Ox liked this post
  7. #5
    Jul 2004
    Southeast Michigan
    6,932
    276
    1757
    I've considered it when it was just a few miles...but 40 may be a bit much! Plus there's a stretch of dirt road that would really suck! lol
    I figured a tow truck would be about $300, since the trailer would be $100...I think that's a pretty reasonable price.
  8. #6
    Jun 2012
    Davis Junction, Illinois
    295
    132
    100
    Roll back wrecker, $75.
  9. Likes tim9lives liked this post
  10. #7
    Jul 2004
    Southeast Michigan
    6,932
    276
    1757
    Quote Originally Posted by Archer120x View Post
    For forty miles?
    Quick...you still buying a coke and a hersheys bar for a quarter?
  11. Likes JohnEvans, morsetaper2, Chazsani, Bobw liked this post
  12. #8
    Virginia
    19,401
    7561
    11777
    Out here, that's a minimum hundred bucks call-out and ten bucks a mile for one that safely manages 8500 lbs. with decent reserve for the awkward goods.
    Local rental agency, it's but $80 drop, $80 recover, but I'm renting THEIR FL, too, that's their own rollback, and I'm a long-term repeat customer within 5 miles.
    If "tow truck" really is only $300, your environment? I would do that and move on to the next priority.
    "Planning" to save that other two hundred seems to always involve several times that figure worth of shredded wallet, if not also the arse meat UNDER it.
  13. Likes Chazsani liked this post
  14. #9
    Jul 2004
    Southeast Michigan
    6,932
    276
    1757
    I've been able to hire a boom wrecker for 75 to lift a bridgeport or something before, but I want to say a rollback was 90 to start then 4 a mile port to port last I checked. But that was for a car.
    I'll call around in the morning. If it's too much, I'll use the trailer...I'd really rather have someone else do it though. Once the trailer gets over about 6,000 lbs I start to wimp out...I'm not a good enough driver and am more than willing to admit it.
  15. #10
    Jul 2014
    Ontario, Canada
    1,079
    753
    698
    Quote Originally Posted by JohnEvans View Post
    Had a boss that did that years ago. The shop truck took off from a light for a left turn and the mould...didn't. It was a 13 km trip, electric lift w/solid rubber duals.
  16. Likes Garwood liked this post
  17. #11
    Dec 2007
    Central Ohio USA
    4,036
    101
    1822
    If it's due any service, see what a forklift repair shop/dealer would charge for pickup/delivery and maintenance. Could be attractive alternative. Pickup and dropoff don't have to be at the same address.
  18. Likes Garwood, Big B, rbdjr59, cyanidekid, wheels17 and 2 others liked this post
  19. #12
    Dec 2004
    uk
    14,046
    4552
    6723
    Other options drop the forks and counterweight and move it as a 2 separate loads and you should be well within that trailers rating.
  20. Likes Pathogen liked this post
  21. #13
    Jul 2004
    Southeast Michigan
    6,932
    276
    1757
    I have a quote of $200 to move it on a flatbed tow truck. Right now it's scheduled to happen tomorrow...so we'll see!
  22. Likes ranchak liked this post
  23. #14
    Feb 2012
    southern Or.
    644
    689
    478
    Years ago I roaded an old Bay City truck crane from Vernonia Or. to Nyssa Or. As far west and east as you could get in the state.
    Top speed with a tailwind was 26 mph. Many mountains and skinny roads. 6 days later the boss was happy to have saved the money on
    the low-boy. Never could figure that one out.
  24. #15
    Jun 2009
    Michigan, USA
    2,990
    3430
    2247
    When I moved a 6,500# cnc a few years ago I was surprised at how much difference there was in the price between many quotes. I had a couple that were over $1,000, one that was about $600 and I finally found a flat bed roll off wrecker that quoted me "around $300". They ended up charging me $265 and also were able to use the hydraulic bed to rotate the machine and push it into place. They also moved it 50 miles and had over 100 miles on their wrecker when they were done. I will definitely use them again if the need arises. It was Buds Wrecker service from Grand Rapids, Mi.
  25. #16
    Jul 2009
    Peoria, IL
    11,754
    51
    9048
    Towing is like the ultimate race to the bottom. I don't know why there are so many towing companies. And they charge peanuts.
    I had a 5,000ish lb mill lifted and set in my shop with a large tow truck, like the kind used to tow semis. He drove 15 miles, moved the machine, and drove back and only charged $90.
    I hire a Landoll truck and trailer from a local towing outfit for $100/hr. One time I thought about buying one until I figured out how cheap it was to hire them.
  26. #17
    Mar 2009
    Eureka, CA
    4,330
    1006
    1722
    I know this thread is over the hill and all the war stories have been told but..not my war story. Almost 40 years ago I was a Millwright at a small mill near Blue Lake, CA and there was machinery to be removed from another mill 30 miles away..right down U.S. 101. Can you believe the mill superintendent had the forklift driver drive his Caterpillar V120 machine all the way to that location..backwards yet, and we're talking a 2 lane freeway and through downtown Eureka...sheesh!
    Stuart
  27. #18
    Oct 2017
    1,267
    397
    435
    I've moved one with a car trailer and one with a dump trailer. The car trailer worked okayish but I really would not recommend either, especially the dump trailer.
  28. #19
    Guest Guest
    For forty miles?
    Heck when I was a kid candy bars were 3 for 25 cents in the supermarket and I am still a little shy of 60. Rates for machinery or vehicle movers can vary quite a bit depending on the competition. Get an area where there is little competition the price can be triple of an area where multiple companies compete.
  29. #20
    Dec 2007
    Central Ohio USA
    4,036
    101
    1822
    Quote Originally Posted by atomarc View Post
    Stuart
    When I was a kid, I watched the remaining XB-70 towed from the old Air Force Museum to the new one, down Route 4 the wrong way on the wrong side of the highway.
    Now back to your regularly scheduled metalworking content.
  30. Likes atomarc liked this post
