Electric forklift battery "refurbishment" question... re load testing/discharge, etc.
Results 1 to 14 of 14
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,660
    3081
    5962
    Default Electric forklift battery "refurbishment" question... re load testing/discharge, etc.
    Do you guys know of anyone who makes a "Battery Renenerator & Discharge" cycler similar to this, besides SBS - Forklift Battery Regenerator & Discharge Cycler | Storage Battery Systems
    Mar 2012
    Geilenkirchen, Germany
    2,819
    1600
    1469
    Quote Originally Posted by Milacron View Post
    When a lead acid battery is bad, it is bad and rarely does it pay in both time and money to rejuvenate. I am also relatively certain this machine is not inexpensive. I am guessing of course, but I cannot imagine you even breaking even on this investment.
    Sep 2002
    People's Republic
    5,970
    715
    3713
    One can buy a lot of standard 6 volt deep cycle batteries before buying either a dedicated forklift battery or this [apparently $12k] toy
    Dec 2000
    51,660
    3081
    5962
    Quote Originally Posted by steve-l View Post
    Not thinking so much in terms of a "bad" battery but rather ones that deteriorate to perhaps 3 hour run time, when as new the truck would go 8 hours. After "regeneration" (sulfur released from lead plates mostly) the battery will never be as good as new but might give perhaps 5 to 6 hours run time for a few more years. Thats been my experience with a constant current changer anyway.
    Dec 2000
    51,660
    3081
    5962
    True (price is right as well) but with the possible exception of electric pallet jacks*, seeing as one needs a dedicated industrial battery for counterweight, why is that interesting ?
    * interesting tidbits about using 6 volt deep cycle (golf cart) batteries to run electric pallet jacks...
    Since the jack's rated capacity includes lifting a heavy dedicated battery, the capacity increases when using 6 volt batteries. The downside is
    a. In my experience, without the weight of dedicated battery the forks won't go quite as low as they should thus getting under 3 1/4" is problematic
    b. Without the weight of the dedicated battery the traction wheels tend to slip way easier when trying to enter a standard pallet... i.e. the weight is needed for traction as well as fork lowering.
    Nov 2013
    Eastern Massachusetts, USA
    6,910
    5911
    6312
    I don't think that unit does anything that you couldn't do manually. It most likely is just charging the battery and then partially discharging before charging yet again. Repeat cycles of that will have some effect on excessive sulfation (sulfate buildup is normal under discharge) as long as it has not got to the stage where plates are damaged.
    My question is will the unit save enough battery life to pay off its cost in a reasonable time.
  7. Likes steve-l liked this post
    Dec 2000
    51,660
    3081
    5962
    Quote Originally Posted by Scottl View Post
    True... hence the purpose of this topic....to see what else is out there of similar ilk for less money.
  9. #8
    Jul 2007
    Missoula Mt
    1,330
    56
    612
    If only runs for 3 hrs the plates are sulfated, try a heavy equalize charge, run flat and do it 3 more times , don't heat up battery, if still only runs lift 3 hrs ...Its shot...Phil
  10. #9
    Apr 2004
    Modesto, CA USA
    8,463
    1606
    I wonder if Tesla and ilk have plans to sell forklift batteries. I understand the tesla battery is just a few thousand double A cells designed for laptop computers.
    Bil lD
  11. #10
    Aug 2012
    California, Central Coast
    5,154
    2376
    2127
    Quote Originally Posted by Bill D View Post
    Bil lD
    I believe they are 18650 batteries, not AA, similar just a little bigger & higher voltage. Trouble is they are light weight so a real counterweight would be needed to replace the lead one.
  12. Likes neilho liked this post
  13. #11
    Mar 2012
    2,819
    1600
    1469
    Quote Originally Posted by Rob F. View Post
    Rob, there is a very good reason why traction batteries are lead acid. Lead acid batteries are safe. They don't internally short out because of dendrite formation and burn. Just ask Boeing or Panasonic. Second, battery capacity and performance doesn't go to hell in a hand basket in temperatures below 10 C like Lithium Phosphate chemistry does.
  14. #12
    Aug 2012
    5,154
    2376
    2127
    I agree completely, you dont see forklifts self combusting in parking lots like the occasional tesla.
    Out here a lot of incentive for people to install tesla power wall back up batteries. I wonder what will happen to them in 10-15-20 yrs down the road as the cells wear out.
  15. #13
    Apr 2004
    Modesto, CA USA
    8,463
    1606
    To be fair at least one Tesla battery that caught on fire was caused by the driver shooting his handgun down into the battery. I think he was driving at the time. I assume the metal bullet caused shorts inside the battery pack. I do not think that can be called Tesla's fault nor a design error.
    Bill D.
    Tesla driver who settled when his car caught fire forgot to mention someone shot the battery with a gun – BGR
  16. #14
    Dec 2007
    Central Ohio USA
    4,036
    101
    1822
    "Hey Ryan, be careful what you shoot at. Most things in here don't react too well to bullets."
    RIP, Sean.
