emcmike
Hot Rolled
- May 5, 2014
- Columbia , SC
There's been a lot of discussion on trailers and I need one. So I broke down what my needs were a designed a trailer to hold 5000lbs. One of the main concerns was to be able to load with little effort. It's still in construction and the stabilizers need to be fabricated to the lifts base. The unit is 12ft long, steel deck , 3500lb axles, will have a powered rear ramp and rear stabilizers. Any feed back would be appreciated. The first move will be a LeBlond Regal 54in. Lathe, on a dolly I designed to hold 4000lbs. All the lifts and winches are 12 volt, winch 2500lb, one mounted front and one in Back under deck, 2 lifts 3500lb each. Here's some pic's enjoy.
