JHOLLAND1
Titanium
- Oct 8, 2005
- western washington state
Are they just doing this for fun. I looked into a set of 4 used foam filled 14.00 x 24.00 take offs that had been removed from the rims so air filled tires could be put back on. The price for the 4 tires was 2500.00 but they wanted another 2000 to install and top off the foam to set them onto my rims. So I know there is already a means to remove foam filled tires off rims without destroying everything. I stayed with air filled..
Rob F.
did your replacement foam fill tires resemble these--I purchased
these for my hyster h60 which has duals--solid
I am puzzling over mounting options
I think the idea is to reuse the tires on rims that fit the lift.
Don't know how they were gonna doo that, seeing how the nice cut right thru
the center of the tread and they pulled off (2) tire halves.
Just like people call can foam (for house sealing) "spray foam"....it don't "spray".Why does everyone call this foam? Look at the video at 10:55 that is NOT foam it is solid urethane. I have had many of these done and I know what it is. Usually the material removed is reused by putting it in another tire prior to filling it to save money, as the material is not cheap. This is known as "chunking".
Notice
