Foam tire Removal
Results 1 to 17 of 17
    Oct 2005
    western washington state
    3,437
    2099
    3288
    Default Foam tire Removal
    Nov 2018
    CANADA
    British Columbia
    153
    27
    102
    Looks like a higher durometer foam. The usual fill is polyurethane and this comes in a wide range of durometers - from shore A10 to A60. The low durometer offers a smooth ride, but the larger deflection under constant movement creates a lot of internal heat that can damage the polyurethane and shorten the life of the tire.
    Jan 2003
    UK
    821
    429
    414
    But they still didn't get the bead of the tyre off, it was in two bits stuck to the rim.
    Jul 2007
    illinois
    487
    38
    Are they just doing this for fun. I looked into a set of 4 used foam filled 14.00 x 24.00 take offs that had been removed from the rims so air filled tires could be put back on. The price for the 4 tires was 2500.00 but they wanted another 2000 to install and top off the foam to set them onto my rims. So I know there is already a means to remove foam filled tires off rims without destroying everything. I stayed with air filled..
    Aug 2012
    California, Central Coast
    2,722
    2084
    992
    My forklift needed tires badly so a quick CL search found a pair with rims. (7.00 x 12)
    Turned out they were filled like in the video. Bolt pattern on the rims was different of course. New ones were old split rim style and forklift had 2 piece rims (inner and outer halfs are same) I removed the lock ring etc on the rims with good tires and they slid off the rims with a little effort and the 2 piece rims went in with about the same little effort. Whole process was maybe 2 hrs.
    The filling was inside a tube so it did not glue itself to the rims, it would have been hard to remove the filled tube from out of the tire though.
    Jun 2013
    Northern Il
    1,170
    650
    1148
    Quote Originally Posted by alcosteam View Post
    I think that in the video, the rim is a split rim that requires getting the rim compressed inward enough to get the locking ring off. If the foam is a hard durometer like it appears to be, you would have a very difficult time to get the lock ring off, hence the tire cutting method.
    Most of the smaller tire applications I have been around, cutting the old tire off was the accepted way to install a new tire.
    Oct 2005
    3,437
    2099
    3288
    Rob F.
    did your replacement foam fill tires resemble these--I purchased
    these for my hyster h60 which has duals--solid
    I am puzzling over mounting options
    Attached Thumbnails Attached Thumbnails 100_2550.jpg   100_2546.jpg   100_2541.jpg   100_2545.jpg   100_2548.jpg
    Aug 2012
    2,722
    2084
    992
    Quote Originally Posted by JHOLLAND1 View Post
    Rob F.
    Yes that style of rim. Do you need to remove the tires from those rims?
    The hardest part of swapping tires on mine was getting the lock ring off, since the tire was filled with foam it would not "deflate" to give room to get the ring off. Took a bit of effort to pry the outer rim down so the lock ring could be pried out.
    If you do not need to reuse the rims I would just cut the ring with a cutoff wheel in grinder, so it comes of in two pieces. Cut into rim as well, since the tire is solid no worries about nicking it either.
    Oct 2005
    3,437
    2099
    3288
    good suggestion on locking ring cut--one or two steel hubs will be sacrificial
    we will see how it goes
    Aug 2012
    2,722
    2084
    992
    If you could rig some way to push down on the outer rim and compress the tire, that will make life easier. Big C clamps or make a kind of reverse gear puller to grab the center of the rim and push down on the outer rim piece. Probably only need to compress 1/2 or 1/3 of the tire at a time, just enough to get that section of lock ring out. Compressing the entire ring would be sure to keep lock ring from twisting.
    On mine I was able to do it with 2 prybars but the lock ring twisted on its way out, so if you need to re use it that method may not be the best.
  11. #11
    Aug 2012
    2,722
    2084
    992
    I just took a road trip and saw a forklift repair truck with a hydraulic press to change the hard rubber tires on his trailer. I had forgotten about these and seeing it on the road was a good reminder. If one of those guys has the right spacers that could be an easy option to remove tires from rims or at the least compress the tires a little to get the lock ring off.
    Here is a link to the type of press used for those tires:
    https://www.mile-x.com/dake-33-493/dak33493
  12. #12
    Oct 2005
    13,505
    Burn pile....Tires don't make smoke at night.
    next morning, take rim from ashes, wire brush lightly, and re-paint.
  13. Likes tdmidget liked this post
  14. #13
    Aug 2012
    2,722
    2084
    992
    I think the idea is to reuse the tires on rims that fit the lift.
    I used to do desert racing in the '90's and one thing I still remember from one of the baja races was some locals had a bonfire going and they were all standing around it drinking beer. This is out in the desert, and it was a tire fire. Lets burn tires and stand next to it, WTF
  15. #14
    Oct 2005
    13,505
    Quote Originally Posted by Rob F. View Post
    Don't know how they were gonna doo that, seeing how the nice cut right thru
    the center of the tread and they pulled off (2) tire halves.
  16. #15
    Aug 2012
    2,722
    2084
    992
    I now see you are talking about the guys in the video, and I was referencing JHOLLANDS tires in post 7
    Good that we were both right
  17. #16
    Aug 2005
    Tucson AZ
    6,169
    9018
    2881
    Why does everyone call this foam? Look at the video at 10:55 that is NOT foam it is solid urethane. I have had many of these done and I know what it is. Usually the material removed is reused by putting it in another tire prior to filling it to save money, as the material is not cheap. This is known as "chunking".
  18. Likes digger doug liked this post
  19. #17
    Oct 2005
    13,505
    Quote Originally Posted by tdmidget View Post
    Just like people call can foam (for house sealing) "spray foam"....it don't "spray".
