Fosdick radial drill move - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 70 of 70
  1. #61
    Oct 2009
    Oregon
    4,578
    4931
    2371
    OK, so now what'chew gunna doo with it?
    (use wise)
    Think Snow Eh!
    Ox
    It's not everyday that I buy a machine too big to fit inside my building, but when I do, I pour a pad for it to sit on and build another building over it.
    That drill makes his garage look pretty small.
  2. #62
    Aug 2002
    West Unity, Ohio
    25,703
    6008
    8292
    Just sayin' that the apps for those machines are significantly less these days.
    Nice to just have around - fer sure!
    Just not sure what I'd doo with it anymore.
    Think Snow Eh!
    Ox
  3. Likes Garwood liked this post
  4. #63
    Oct 2009
    Oregon
    4,578
    4931
    2371
    I have a little 3' arm one and I forgot I have it on more than one occasion. Quick change tooling and all the bells and whistles ready to go, but I rarely turn it on. I think I've spent more time oiling the column and wiping it down to keep it in good shape than I have using it. Biggest job I ever used it for was drilling and tapping the ends on a pickup load of larger sized electric motor armatures. That was probably only 4 hours of work.
    I do like that mine is light enough I can just fork it close to where I need it. Mine's got a twist lock plug on it so I could prolly take it outside if I really needed to.
    Big local auction of an old school heavy machine shop had one of those 1920's era all angle type radials. The shop would crane that thing up onto big stuff they were working on (shop had rail spur going through it) and weld it in place. Drill or bore whatever then scarf off the welds and move onto the next hole. Guess that's whatcha do when the holes get too big for the mag drill.
  5. #64
    Apr 2006
    Manchester, England
    8,566
    1318
    5514
    You've got a very nice drill there. That machine is worth going to the trouble you took to get the lift rigged correctly. I would have had the main lift shorter going into the crane hook so the balancing lift going to the column would be at about 45 degrees but apart from that everything you've done is by the book.
    Your lifting bracketry is almost identical to the ones I used. I don't know about your tee nuts but I used full length shop made tee nuts, ie tee nuts as long as the lifting brackets. The more lifting area on the tee nuts the better.
    Well done, Tyrone.
  6. #65
    Aug 2002
    West Unity, Ohio
    25,703
    6008
    8292
    Quote Originally Posted by Garwood View Post
    Post about building one of two 408's that I bought:
    Excello ?
    Quote Originally Posted by Walt @ SGS Inc. View Post
    ..................... a 408 Excello is one big big machine. I had to do some machining on the spindle housing, we just set a bridgeport on the table and had at it. We had a bunch of Xs abd Ys and Zs along with two B axies if you counted the Excello Table (B) and we could swing the ram of the Bridgeport as we needed.
    Walt..
    Think Snow Eh!
    Ox
  7. Likes Garwood liked this post
  8. #66
    Apr 2006
    Manchester, England
    8,566
    1318
    5514
    I knew I'd seen an illustration somewhere of an " Asquith OD 1 " rigged correctly. If you go onto the " Lathes.co.uk site there is a section on " lifting drills, mills etc ". Scroll down that and you'll come to a drawing of the correct method. There is also a photograph of the correct lift but for some reason the photo is skewed on the page giving you the wrong impression of which way the drill should be leaning when it's been lifted.
    Regards Tyrone.
  9. #67
    Aug 2002
    West Unity, Ohio
    25,703
    6008
    8292
    "Correctly"
    ... at least per someone.....
    Think Snow Eh!
    Ox
  10. #68
    Apr 2006
    Manchester, England
    8,566
    1318
    5514
    "Correctly"
    Think Snow Eh!
    Ox
    If it's good enough for " Asquith " it's good enough for me. They probably built more radial arm drills than any other maker so I presume their method was tried and tested.
    Regards Tyrone.
  11. #69
    Jul 2004
    Asheville NC USA
    8,875
    3627
    3025
    For future reference, a 5 ft X 13" column Fosdick weighed 12,100# crated for shipment per the Federal Register of July 1943. Page 10,188 if anyone wants to look it up
  12. #70
    Virginia
    28,971
    7561
    9002
    Quote Originally Posted by metlmunchr View Post
    Ummmh.. I don't REALLY even want to read the first ten pages, let alone 10,187... plus one... actually.
    Yer one Helluva dedicated researcher, though!
    Wonder what the Federal Register ITSELF weighed, that year?
