Freeze Plug Repair?
Results 1 to 14 of 14
    Dec 2018
    Illinois
    Default Freeze Plug Repair?
    Greetings!
    We have an older Clark Yardlift (gas) with a Continental flathead motor.
    It ran great until today a "plug" or something like it broke on the left-hand side of the engine resulting in a gush of engine oil.
    To me, this seems to be a cavity that would typically be sealed with a freeze plug, but what's in there now is something different. Perhaps a bad epoxy fix?
    Anyone have the ability to identify? We're in the early part of troubleshooting
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,049
    844
    693
    Looks like failed epoxy glob repair to mysterious bullet-hole in valve cover of flathead engine.
    Remove cover, weld or bolt-plug hole, clean plate and mounting surface, replace with new gasket or sealing goop.
    Jan 2011
    BFE Nevada/San Marcos Tx
    803
    694
    396
    Kinda hard to tell what I'm looking at in those pics, freeze plugs are on water side of block, if oil dumped out it would be an oil galley plug, looks just like a freeze plug, but you know, its gotta have a different name. If its a nice round machined hole, measure and go to NAPA, if not nice round hole, idk, maybe some JB weld lol.
    Oct 2016
    Florida
    237
    504
    155
    Pull the cover off. Fix the hole. Clean. New gasket. Put cover back on. Add oil to correct oil level. Use it.
    Love old engines.
    Feb 2012
    southern Or.
    638
    651
    468
    valve lifter and adjustment cover. Remove and weld or goober it up again. Cork gasket will work best. Good time to check valve adjustment as they sometimes get tight and will float a valve. There may have been a vent tube there if the hole looks round and fabricated. If it has been working fine just plug it.
  6. Likes Mud liked this post
    Mar 2011
    Geneva Illinois USA
    5,691
    2349
    2191
    probably was a crankcase breather. It is common to have check valve breather on the valve cover. These allow pressure buildup in the crankcase to vent and then on the piston upstroke to draw a vacuum on the crankcase. Without this there will be a lot of piston blow by. Old engines simply exhausted the valve to atmosphere, modern ones into the intake manifold.
    I would not plug it as suggested.
    Tom
  8. Likes DrHook, Matt_Maguire, ronf, tdmidget liked this post
  9. #7
    Oct 2013
    South Dakota
    199
    2072
    84
    My old 1952 Yale has a breather tube in that location. Somebody must have "fixed" that one.
  10. Likes dalmatiangirl61, Bobw liked this post
  11. #8
    Oct 2009
    Olympia, Wa
    594
    300
    171
    I also have an old forklift with a continental and mine has a breather tube here as well.
  12. #9
    Dec 2012
    AUSTRALIA
    1,416
    6
    431
    Its a breater,allright,and there may be a baffle inside the cover that filled with oil when the hole was blocked..........hence the oil leak will stop .On mine ,there is a bypass oil filter that returns via that hole,and any crankcase fumes come out the oil filler cap.............there will be no excess oil in the tappets,as there are drains down into the crankcase all along...(big enough to drop valve cotters in ,if you are not careful).........note the Continentals had a pin through the valve ,not two coned segments like a modern engine.
  13. #10
    Jul 2009
    Peoria, IL
    11,542
    48
    8822
    Yeah there should be a breather tube there. And a baffle that covers the hole inside.
    I don't think you can get that tappet cover off without removing the manifold, so I'd count on that. Is that a 4 or a 6 cylinder? I might have a spare for a 6 cylinder. Looks like a 4, but hard to tell.
  14. #11
    Sep 2012
    California, Ventura county
    1,391
    254
    600
    yup should have a baffle with a Brillo pad like filter
    on the inside a pretty much all engines of that era had breather tubes
    about there and running down
  15. #12
    May 2016
    Tennessee
    384
    54
    195
    Quote Originally Posted by dalmatiangirl61 View Post
    The term “freeze plug” is kind on a misnomer also. They are really all just casting plugs. While on occasion, a “freeze plug” will blow when the water freezes and save the block or head, that isn’t it’s purpose. It’s main purpose is to get the sand out of the casting.
  16. #13
    Jul 2009
    Peoria, IL
    11,542
    48
    8822
    Actually, to be really technical, often the purpose of the hole is to provide a place to hold the sand core in the larger sand mold during the casting process. I think the actual name is a "welch plug", but I've always heard them referred to as "core plugs". That's my preferred term.
  17. Likes TDegenhart liked this post
  18. #14
    Mar 2007
    2,049
    844
    693
    I agree with the folks that think it is a breather. I shoulda thought more the first time.. so you might want to braze a tube onto it to allow directing the blowby...perhaps into intake/ You could add a PCV valve.
    I see two common types of casting hole-plugs. One is a shallow drawn cup...sometimes called a core-or cup-plug. The "welch" plug I think is a shallow dish which expands a little when the convex side is pressed on. IME the cup style is better. Seals better, less likely to fall out, more tolerant of hole size variation
