Full and sudden failure of a fork
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Aug 2004
    GERMANY
    1,798
    18
    374
    Default Full and sudden failure of a fork
    Ok, this was abuse. We were moving bundles of steel beams hanging from straps up a narrow steep path. A telehandler holding up the rear and a rough terrain forklift the front (going backwards).
    Telehandler had a single FEM3 size (full size in my book) 2 meter fork with the strap hanging at about 1,80m out and about 2 tons of load.
    The fork was bending but not deforming, but then it suddenly broke at the root and the load fell about a foot.
    No biggy, but impressive failure mode.
    Picture taken the day after, slight rust from rain.
    Last pic shows mud on parts of the break of the vertical fork part..
    win_20210511_16_54_03_pro.jpgwin_20210511_16_53_52_pro.jpgwin_20210511_16_54_22_pro.jpg
    Jul 2006
    Hillsboro, New Hampshire
    12,948
    2938
    8932
    Sounds like you got lucky, that had been waiting to fail for a while...
  3. Likes BugRobotics, BT Fabrication liked this post
    Oct 2005
    21,573
    Quote Originally Posted by Martin P View Post
    They doo that. You were thinking maybe they would simply bend ?
    Don't work them hard like that.
    Aug 2004
    GERMANY
    1,798
    18
    374
    Yes I expected plastic deformation and have seen that some.
    I saw a rental recently where the forks were bent about 5 degrees down.
    Mar 2009
    Eureka, CA
    4,361
    1014
    1745
    On a side note, that fork is repairable, I've done it. A properly re-welded fork is just as strong as a virgin fork when the repair procedure is followed to a 'T'.
    Stuart
  7. Likes JoeE. liked this post
  8. #6
    Mar 2010
    Davidson NC USA
    1,532
    627
    948
    The top of the break suggests a previous overload stress crack that propagated into the total failure.
  9. #7
    Jun 2016
    New York
    2,138
    1710
    1051
    go magnaflux your forks folks!
  10. Likes mkd liked this post
  11. #8
    Dec 2012
    AUSTRALIA
    4,388
    21
    1605
    Some years ago ,I got the job of reassembling two Hyster 520s at an auction yard...I had to make some of the pins for the masts that were "too costly to buy off Hyster"......anyhoo,the giant forks on both had been crack tested with dyecheck,and the bends were full of small cracks......the auctioneer came out with a wire brush and removed the white coating.....Both forklifts were from Queensland Railways....who used to maintain their equipment better before they were privatised.
  12. #9
    Oct 2005
    21,573
    Well, Chinese steel strikes again.
    There are no standards anymore.
  13. #10
    Jun 2014
    New Jersey
    351
    356
    187
    you sure? How do you know that?
    and that's the only reason? No chance overloading, and previous damage?
    just curious how you know it's chineese metal... I don't doubt it, but I don't know.
  14. Likes Strostkovy liked this post
  15. #11
    Jul 2007
    Missoula Mt
    1,356
    58
    635
    "On a side note, that fork is repairable, I've done it. A properly re-welded fork is just as strong as a virgin fork when the repair procedure is followed to a 'T'."
    Stuart
    You are out of your mind, no way will OSHA allow a welded fork, and how would you put the heat treat back into it? Forks are forged and heat treated for a reason, and next time it breaks you might kill someone. Both forks should changed out with new ones and the old one cut up for scrap. Just like a airplane wing so many flex,s and they will snap...Phil
  16. #12
    May 2017
    Massachusetts
    340
    21
    95
    Quote Originally Posted by atomarc View Post
    Stuart
    Is there a standards organization that established this repair procedure?
    These fork failures are likely related to cyclic loading(bouncing load), which is why it broke in a brittle manner at a load below the yield or tensile strength. It is basically accumulated damage that can result in cracks that cause a brittle failure. Damage to the surface of the forks can cause a stress concentration that further exacerbates this process.
    I can't imagine any repair that would fix the accumulated fatigue damage in the adjacent areas and would cost less than just getting a new fork. That, along with fatigue challenges related to welds makes a repair extremely suspect. Static load capacity is far from the only design requirement for a fork. You need to accommodate fatigue because have to be thin, and therefore flexible, which causes a lot of fatigue.
  17. Likes cyanidekid, tim9lives liked this post
  18. #13
    Mar 2009
    Eureka, CA
    4,361
    1014
    1745
    Well fellas...you have to be smarter than the fork and know how to follow a welding procedure. When I did the deed, there was no such thing as OSHA, you had to use your brains. It's much different today...but as Phil noted, I'm probably out of my mind.
    Welder-Stu
  19. #14
    Apr 2020
    1,245
    1086
    444
    I wouldn’t weld that and I’ve done some SKETCHY shit with a welder and that’s no something I would do.
    The internal stresses in the weld/filler would be pretty bad if not tempered back I would think.
    I also get the vibe if the welded fork snapped at the weld you’ll possibly get some “energetic fragmentation”.
  20. Likes ernieflash, tim9lives liked this post
  21. #15
    Mar 2009
    Eureka, CA
    4,361
    1014
    1745
    Well Mr. Blob...that's why you preheat, peen, post heat and use a filler that's compatible with the original metallurgy of the fork. It a recipe, just like making brownies...if you forget to put in the weed, the brownies will just plain..suck!
    Ganja-Stu
  22. Likes Scruffy887, Cole2534, Hillside Fab liked this post
  23. #16
    Jul 2006
    12,948
    2938
    8932
    Quote Originally Posted by Homebrewblob View Post
    From the owner or user of the fork lift, if nothing else.
    I'm going with "replace both tines", and with a known-good US maker. I have a pair of cheapass CN tines that will be used at a very derated level for an inhouse purpose, but otherwise would only use US, CA, or a good EU brand.
  24. Likes Homebrewblob, tim9lives liked this post
  25. #17
    Apr 2020
    1,245
    1086
    444
    Ganja-Stu
    Well heck, might as well forge you some new pokies at that point.
  26. #18
    Apr 2020
    1,245
    1086
    444
    Can’t argue with that
  27. #19
    Mar 2009
    Eureka, CA
    4,361
    1014
    1745
    Been around forklifts for many a moon and not once..until post #16 have I heard them referred to as 'tines', must be a New Hampshire 'thang'!
    Tine-less Stu
  28. #20
    Jul 2006
    12,948
    2938
    8932
    Tine-less Stu
    Get with the tines, young man. We in the Great Northeast are hep, mod, and with-it, so know all the nomenclature...
    Forklift Forks and Tines Guide | Learn Before You Buy | Tontio
