Bill D
- Apr 1, 2004
- Modesto, CA USA
In general forklifts that run on propane are they just low compression gasoline engines with a different carburetor. Or, are they higher compression engines designed to run efficiently on propane, probably converted from diesel.
I ask because I had asked about propane fueled big rigs and found that propane likes to run much higher compression the gasoline engine. As in Diesel compression pressure ranges.
Bill D.
Bill D.
