Getting a lathe off a pallet - Page 2
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 87
  1. #21
    Aug 2006
    317
    71
    Default Getting a lathe off a pallet
    Quote Originally Posted by mpmar_bt View Post
    Since you have use of a fork truck I would lift and block it up one end at a time. Then just slide the forks under and away you go. Move the pallet and then set it down on the same blocking on the floor. You know the headstock end lifting point. As for the tailstock end I would look for a through web on the base where I could use a heavy lift strap basket style. Hook the strap over the fork and ease it up just enough to slip the 4X4 underneath and then ease the lift back down.
    You want to end up like this:
    Attachment 261780
    My thinking is that blocking one end at a time will keep the other end on the ground so pretty stable as long as you move slowly and only lift it enough to block it.
    I left mine on 4X4s so I could get under it with a pallet jack. That would be a bad plan for most lathes but the base on that guy is so solid I don't think wood movement will affect it.
    Thanks. Picture is worth a thousand words. That helps. Think Iíll have to cut away part of the pallet to do as you suggest. For more pics and issues with this lathe, see my thread in the Monarch section.
  2. #22
    Aug 2015
    Illinois
    1,348
    971
    576
    I assume the lathe was put on the skid with a crane. Easiest way off is with a crane, gantry, or whatever. Three of the lathe I have owned recommended lifting using a sling around one of the cross members of the bed. Unless the bed construction of the Rivett prevents doing that, I think that is the best way to lift and move a lathe.
  3. #23
    Jul 2014
    Ontario, Canada
    1,026
    731
    662
    Over 48 hrs have elapsed...hopefully he's got it off the skid by now.
  4. #24
    Aug 2006
    317
    71
    Quote Originally Posted by RC Mech View Post
    Unfortunately no! Still waiting on my friend with the big lift.
    Sent from my iPad using Tapatalk
  5. #25
    Sep 2016
    Missouri
    778
    665
    217
    I agree with those suggesting lifting with slings. Lifting from the bottom is ok but is less forgiving on unlevel terrain or a jerk of the clutch. If using forks strap the lathe to the mast while traveling.
    I tipped my Ingersoll Rand type 30 air compressor before I had time to react. It only damaged the air cleaner but that was $80.00
    Tipping an older lathe can result in a total loss.
    We all have seen tipped lathes here on the forum..
    That's a nice lathe. Accept the colors, easy fix for that
  6. #26
    Jul 2005
    Cottage Grove, MN 55016
    7,590
    4093
    4537
    http://vintagemachinery.org/pubs/2379/20326.pdf
    also this one has photo's near the back with that cover off. http://vintagemachinery.org/pubs/2379/4491.pdf
    The first one says to use lifting hooks. I would also say you could probably call a local machine mover who could do it in 10 minutes and you might take a day or 2, have to buy hooks, chains, straps, engine lift, etc. and get hurt if your not knowledgeable. Or tip it over and ruin the machine. Call around and find a company who move printing machines as they are equipped with smaller forklifts and I find them to be cheaper.
  7. #27
    Aug 2006
    317
    71
    For fear of damaging it I may call a rigging company. I admittedly don't know what I'm doing.
  8. Likes mllud22, Hodge liked this post
  9. #28
    Jul 2008
    South Carolina
    622
    214
    371
    Quote Originally Posted by TravisR100 View Post
    Good call, not nearly as expensive as a damaged lathe. It's not a hard job if you have been exposed to this type of work but can be daunting if not.
  10. #29
    Aug 2012
    California, Central Coast
    3,324
    2153
    1293
    Just get a tow truck, the old style with a boom and winch.
    Or can you hook a hoist to the ceiling?
  11. #30
    Virginia
    26,034
    7561
    8214
    Quote Originally Posted by Hodge View Post
    Cheap, too. But not a lot of help unless the OP has seriously high ceilings and door opening to match.
    EX:
    My first 10EE, the seller had called-out a basic auto-wrecker, rigged for sling lift from above through the bed web so no issue with rods or controls, pallet just hung there under it.
    $80 plus a $20 tip, and I hit the road in short order.
    Unloading, I used a heavy Korean dual-pneumatic tire FL to insure my uneven driveway was less of a risk as to side-tip. ISTR the rent with drop & recover was close to $400.
    And THEN.. I had to timber-shove it back into the shop under a very low roll-up door opening. The sawzall work to get it separated from the pallet - described above - still had to follow all that work and expense.
    That said, I would surely have had MORE work and greatly increased risk of tipping it over had I removed the pallet outdoors, then had to get the "naked" lathe into the shop without the stout pallet working for me against a face-plant disaster - or build NEW skids to replace the pallet, just for the last 20 feet or so.
  12. #31
    Nov 2018
    Vermont
    152
    69
    32
    I bought a hydraulic stacker for $600. Used it for moving a CMM with a heavy casting, around 2500 lb, and shimmying the robodrill around a bit. Also works perfectly for taking the 5-axis trunnion in and out. A bit pricy, but you might find one in your area for cheap, and if itís one time use, they sell pretty easily.
    Sounds like youíre already there though. Iíve seen hundreds of tons of locomotive moved in some interesting ways in some hard to reach places with nothing but pry bars and hardwood blocking. Hiring riggers seems a bit much for as far as youíve gotten.
  13. Likes RC Mech liked this post
  14. #32
    Sep 2010
    Oklahoma City, OK
    4,161
    718
    1757
    Engine hoist to pick up the tailstock end and then roll a bar under it past the balance point. Set it down, headstock end come up. Slide a bar wider than the pallet under the headstock and crib it up above the pallet. Use hoist to pick up tail end and slide the pallet out.
    Lower tail onto cribbing. Pick up head, remove the bar and crib it even with tail. Now is a great time to slide a pallet jack under it, btw.
    Work the hoist back and forth, removing a little cribbing at a time. Strips of 3/4 plywood are perfect.
    It's time consuming but pretty safe as long as you move slowly and work in small increments.
  15. #33
    GERMANY
    2,608
    1611
    903
    I had to get a cylindrical grinder 1.8 metric tons, so about the same weight off a pallet a year ago. Problem was even nastier, because the grinder occupied the entire top of the pallet - there was less than one inch of pallet showing on all four sides. I had nothing over head to lift with, and the grinder is top heavy.
    What helped me was that there were M20 threaded holes in each corner of the base for adjustable feet. But the feet were packed separately so the threaded holes were empty. So I bought one meter of M20 threaded rod, and made up two wood beams (cross section was 100 x 200mm, so 4 x 8 inches) which I then attached to the base above the threaded holes, one in front and one in back. The beams were longer than the machine by about 200mm (8") on each side.
    I then used a pair of hydraulic car jacks to lift the beams sticking out on the right hand side. Once the weight was off the pallet, I put in a stack of plywood squares that I had pre-cut for this. These went underneath the beam ends on the right hand side. Then I shifted the hydraulic jacks to the left side of the machine, lifted the beams on that side, put those beam end onto plywood squares. Now that the weight was off the pallet, I just pulled the pallet out from under the machine. With the pallet was out, I put a 2.5 ton hand pallet jack under the machine, lifted it, removed plywood squares from beams one at a time, and lowered the machine to blocking near the ground. Then removed the wooden beams, inserted feet and steel footing plates, and used the foot screws to jack the machine up a few mm to remove the last blocking. Then used the foot screws to lower machine onto its feet.
    Looking at your lathe, I can see that there is a gap between the pallet and the machine base. If that gap is wide enough, you can get a pair of sturdy steel bars long enough to extend 8" past the pallet on each side, insert them (front to back) in that gap, and then jack up the ends of those bars and put them on a plywood stack. If you do this, attach stops to the bars so that the machine can not slip forwards or backwards on them. I would also use some wood pieces clamped to the bars to keep their spacing fixed.
    Then remove the pallet and put a stack of plywood squares under each corner food. Then use a pallet jack to start lowering the machine. Since the jack won't lift as high as your pallet, you will need to go in stages with some spacer layers of wood on the fork of the jack, removing plywood squares from the corners in steps.
    By the way, some good advice I got was "do not do this with a helper". Plan each stage and do it alone. A helper is a distraction and adds time pressure. It also tempts you to try and use muscle power. That's hopeless against this weight. You should never be rushed, and never be struggling or breaking a sweat. If you can't do it alone, you need a better plan.
  16. #34
    Virginia
    26,034
    7561
    8214
    Quote Originally Posted by ballen View Post
    Seconded. Or maybe we are going circular? 'coz I learnt it, then passed it on!
    Safety at a distance with a cellphone to call EMT is OK. Long as they keep the distance.
    And their distracting mouth shut.
    I can't be bothered. Long past my sell-by date, anyway.
  17. #35
    Jun 2016
    New York
    1,453
    789
    618
    Sorry, ballen, have to disagree with that!
    Donít do it with the wrong helper, that CAN be really bad. Someone who is impatient, anxious, or dumb, (or worse all three) can be a disaster.
    someone who is calm, reasonably intelligent and takes direction well is really good to have around. Even if they donít have experience moving heavy gear, they can at least call emergency services. The mere thought of being trapped by a heavy machine with no one to raise the alarm is terrifying.
  18. #36
    Aug 2006
    317
    71
    I really appreciate all the suggestions. Itís still sitting on the pallet at the moment but I havenít been in a rush. Itís been nice having it in the middle of the shop while Iíve worked through electrical tracing. Lots of space on all sides.
    Ballen, that gap you see only goes about 3Ē then itís solid to the pallet again.
    Thunderskunk, is that what they call a roll-a-lift?
  19. #37
    Aug 2012
    3,324
    2153
    1293
    roll a lift is like a hand dolly with a hydraulic lifting mechanism, they are used in pairs.
  20. #38
    Virginia
    26,034
    7561
    8214
    ...is that what they call a roll-a-lift?
    Rol-A-Lift: Home
    Rentable, many places. Need a bit of care to use safely.
  21. #39
    Nov 2018
    Vermont
    152
    69
    32
    Naw, thatís a bit different. Mine has legs under each fork, just as long and with wheels.
    Found this in your area:
    electric yale stacker 24v - heavy equipment - by owner - sale
  22. #40
    Aug 2012
    3,324
    2153
    1293
    Quote Originally Posted by thunderskunk View Post
    Naw, that’s a bit different. Mine has legs under each fork, just as long and with wheels.
    That looks a great deal, out here something like would start at $2500 or be a complete roach.
