Grove articulated boom lift - operation ? - Page 2
Likes Likes:  0
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 72
  1. #21
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,038
    423
    1014
    Post
    Nice lookin' lift there DT [img]smile.gif[/img] While a scissor lift can come in handy for tasks like hanging pipe, conduits or light steelwork as they can be raised level on the work platform, the articulation lets these go nearly anywhere you can "shoot the boom".
    All I can tell you from similar JLGs is that the defining moment appears to be when you step on the footpedal and hear the audible sound of a relay pull in.
    I see your control speed is set to "rabbit" on the main panel, but make sure it hasn't been turned to "turtle" on the same feature inside the basket [img]smile.gif[/img]
    The Estop may twist to release but highly unlikely it would move at all with the Estop depressed.
  2. #22
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,284
    2785
    5589
    Post
    In the basket there is no turtle/rabbit knob, but rather (I presume) the speed is controled the same as on my scissor lift, and that is they both have joystick controls and you press the joystick in the direction you want to go...the further you press the stick the faster it goes.
    The interesting difference on the Grove is since it will rotate 360 degrees, you tend to get confused about which is the "front" and "back" of the chassis, so you go by back arrow vs white arrow on the joystick taking note of same large decals on the body to know which way the device will travel when you press the joystick. A handy feature if near the edge of a loading dock
  3. #23
    Mar 2007
    Acme, Wa
    7
    Post
    We have a lift at work that requires it to be faced in one direction or it goes at a slow snail pace. The 180* thing is the only thing that really pops in my head.
  4. #24
    Jan 2007
    Ca
    25
    Post
    I had used one that was messed up and only worked one way thats why the 180, its worth a shot. If grove has a website you may be able to d/l the manuals. I know genie has them ava online.
  5. #25
    Sep 2003
    New England
    781
    84
    Post
    don, i know nothin about these things..but is it possible..say when you lifted it with your forklift that a switch is tripped (too much tilt)..and you need to re-activate something, now that the conditions are better? (ie you are not upside down). course if you knew this you wouldnt be askin! but maybe it rings a bell with someone
    scott
  6. #26
    Dec 2000
    51,284
    2785
    5589
    Post
    Besides being extremely obvious, if you will re read the posts here you will see that Dirt already tried that..and he is really good at finding obscure info on the internet, thus your comment is pretty redundant don't you think ?
  7. #27
    Mar 2006
    Ct
    73
    21
    Post
    There is a secret..............and I know it. Do you want to know it? I will tell you if you ask nicely.
  8. #28
    Dec 2000
    51,284
    2785
    5589
    Post
    coz...ok, pretty please with cherry on top for my "cherry picker" ?
  9. #29
    Jan 2006
    NC
    752
    Post
    The Grove GPX, CAPX, and D3 all require user name and password. The serial number is required for registration to access. Further confusion is added by breaking down man lifts into vertical mast lift, articulated boom, straight boom telescoping, then Grove, Manitowoc, and National Crane. That's just the man lifts
    The Master Document list for Grove does not show model numbers for manuals listed, but shows a group of part numbers for the manuals based on serial numbers in a generic PDF document, if that makes sense. Then, after you get through all that, you still have to go through the registration mess to figure out if it can be downloaded from either D3, CAPX, or GPX.
    As far as a manual goes, I'd call the Greg Poole place above to see if that's how it works or if it's dealer only. Some of the troubleshooting manuals were listed as such. It is a highly convoluted mess there to figure out, and it all loops you back to the brochure if you can't login.
    In short, yes, I did look for the manual to download or even a generic version by going to my favorite military manuals site (NOT Tpub), not even restricted versions were found. None at dealer sites, where they sometimes are "inadvertently" available. I know its out there, just gotta find it. The world is my library.
    Anybody can guess, but they wrote it down so you don't have to
    I have a guess but no electricals, so its only a guess.
    Coz, please tell.
  10. #30
    Feb 2007
    Washington Court House,Ohio
    42
    Post
    Hey guys this is sort of off the subject I had a problem with a Gennie,going up to remove old piping from a crane rail and paying attention to a gas line on a colum, shoved the basket up under the crane rail and crushed my hand between the boom and the crane rail with my hand still on the up switch. When I got back form the Doc. the Co. had allready put a gaurd over the controls. The safety report still read it was my fault! That one would go 180 but not 360 but went real slow when backwards, I would check the boards if it's been wet,the contacts my be green.Clean with a pencel eresar, don't go crazy with the pressure just enough to remove the crud hope this helps. Charlie
  11. #31
    Mar 2006
    Ct
    73
    21
    Post
    I know a little about lifts....... but not about engine hoists............now I'm confused!?!?!?
  12. #32
    Dec 2000
    51,284
    2785
    5589
    Post
    coz, in other words, you are FOS about knowing the "secret" to traction controls of a Grove articulating manlift.
  13. #33
    Mar 2006
    Ct
    73
    21
    Post
    Yup FOS...............so you are SOL. The secret is to buy a manual. You would nail anyone else to a cross if they asked the question you asked. You nor anyone else should operate any lift without first reading the manual. I don't care how much you think you know.
    As always, best regards Mr. Thomas
    Coz
  14. #34
    Apr 2007
    Wisconsin
    5
    Post
    Did you check out the FWD/REV contactors, the fuses, and the Battery Voltage & water levels. The drive motor(s) draw the most load and the Hydraulic pump will work when there is not enough juice to run the Drive Motor(s). Battery cells should be greater than 2.0 volts each and specific gravity should be about 1250 or better. You may just plain have junk batteries, (usually the root of the problem). Hope that this helps. Keith
  15. #35
    Jan 2006
    NC
    752
    Post
    Can't find a dang thing about it specifically, so I'm going to guess based on a$$umptions and generic interlocks, we know how that goes
    Assumption: Machine must work, its only showing 296.7 hours so little if anything wrong. Its shown sitting in yard of other equipment and it didn't fly there. Lets assume batteries are adequately charged, hydraulic reservoir level good.
    Guess: A combination of control select keyswitch and E stop pb. Try E stop depressed, control function to ground, spring return to platform cntrl, pull E stop, and try the bucket functions. I'm guessing the E stop needs to be pulled the last thing in the circuit to use the foot pedal enable for bucket control.
    Note: Some machines have brake pumps to release the brakes during unforseen circumstances. It would look kinda like a manual fuel primer pump accompanied by all sorts of warning decals I'm sure. I believe with no pressure/resistance felt at the manual pump the brakes are locked. If so equipped, that may assist with troubleshooting symptoms.
    Without electricals and contact developments I'm stumped.
  16. #36
    Dec 2000
    51,284
    2785
    5589
    Post
    Keith, yes, checked all of those. Total battery voltage is currently 49.4 volts (48 volt system), however SG is a bit low at 1150 average. Still, full charge at 51 volts would help that.
    When I press the traction joystick I can hear contactors in the chassis click into engagement and the motion alarm begins to beep but no wheel movement whatsoever. Looking more and more like electronic problem as all fuses and corrosion issues looks good. Servocon board looks suspect.
    coz, I would never, "nail anyone else to the cross if they asked the question I asked" I challenge you to present a single instance of where I may have fretted at someone for asking a question of this nature. You have over 19,000 posts to select from, so if it ever happened shouldn't be hard to find some examples.
    If you don't, then 20,000 members can assume you are the foolish troll you appear to be.
  17. #37
    Mar 2003
    Toledo Oh
    756
    Post
    Have ran some that had a speed contral on the joy stick.
    David/Toledo
  18. #38
    Apr 2007
    Wisconsin
    5
    Post
    You Might try a draw down test. 1150 is low. I am not real familiar with Servocon Controller. You might look for flash codes. Keith
  19. #39
    Apr 2007
    Wisconsin
    5
    Post
    Also, you can check the motor(s) for shorts to ground and bad brushes/commutator. Keith
  20. #40
    Mar 2006
    Ct
    73
    21
    Post
    You are amazing!!!!! Your ability is uncanny. 3 posts ladies and gentlemen and he’s got it. You hit the nail right on the head. You are right, I am foolish and a troll. How do you do it? Actually I’m only a little foolish, that’s why I end up here from time to time. I have watched you bully and demean members in almost every thread you are a part of. I think I would really enjoy meeting you in person. Should 20K posts impress me? I’m out doing it while you are here talking about doing it. Buy a manual. Read the safety section first. You will probably find what you are looking for. I have been looking for a good reason to call you the dick that you are for some time now. This as good as any. I won’t be back and I don’t think I will be missed.
