Homemade Rigger's Boom - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
  1. #41
    Feb 2008
    Mishawaka, IN
    343
    40
    82
    Default Nice boom; what about the fork hook group
    Quote Originally Posted by Alexjm View Post
    Its amazing and the exact numbers are not known!
    I see you have bolt on fork upper hook group-- did you make those yourself or did you find a supplier for those?
  2. #42
    Jun 2016
    New York
    1,517
    840
    656
    necro thread... BUT...I wouldn't lift anything with it myself the way the weld looks between the vertical and the upper mounting plate.
    the load there will be almost all tension, and it could open up zipper style. the load will be concentrated at the very top of the weld, if there is a flaw there...
  3. #43
    Dec 2012
    AUSTRALIA
    2,091
    9
    627
    The structure proves itself in use......big risk with these lifting booms is if the narrow wheel track goes in a hole one side,the fork tips alarmingly.....a hardly noticeable hole,too.......I got a similar fork,and I put dual wheels on mine to make the track much wider for a lifting boom.
