How to set up Overhead Crane to move items into Paint bay
Likes Likes:  0
Results 1 to 12 of 12
    Oct 2014
    South Dakota
    83
    7
    Default How to set up Overhead Crane to move items into Paint bay
    We are planning an addition to our shop. The main necessity is a paint area for large items we manufacture. Thinking of going 45' Wide by 80' Long and 20' sidewalls roughly. The Paint area would be on the last 30' of this building. We originally planned to close this off so paint fumes and steam from washing would not enter the rest of shop. We want to put a crane in the 50' part for fabrication area. Now we have located 2 used 5 ton bridges approximately the right width for a good enough price we are considering adding both to our rail. Is there a good way to have the paint bay sort of closed off and still run our crane over the wall to carry things into the paint bay in place of forklift? Best idea we've had is build the wall with a gap for crane. We would still have a doorway in middle, then some sort of flaps to close the gap up there.
    Jul 2006
    Hillsboro, New Hampshire
    9,949
    2310
    6946
    My two cents - don't have any perforations on the roof or walls if you want a clean area for painting. It invites dust, and also makes venting of fumes to the outside more difficult.
    Look into setting up some painting dollies of a few sizes and load capacities. A stiff, low platform, anchoring points, and good wheels (not castors, fixed wheels to go straight in and straight out).
    Load your parts on the dollies in front of the painting area, clean/dust everything, then bring into the paint booth. Should give good flexibility and reasonable material handling. Add a couple winch points inside and outside the booth if needed for heavier moves.
    Mar 2013
    BRAZIL
    2,177
    2564
    1370
    What kind of finish you looking for? If its less than nibless glass off the gun you can build the room as a tunnel, have the crane run in the tunnel. Place your extraction with a large filter wall at the far end and run the entrance of the tunnel open. Run enough extraction so no vapour escapes the entrance.
    With the floor wet down, the masking tight and guys that halfways know what theyre doing, you can get pretty sensible finishes providing the incoming air is reasonably clean.
    Super cheap low maintenance setup providing youre allowed to go this way.
    Cheers
    D
    Mar 2009
    Eureka, CA
    4,088
    910
    1541
    Wouldn't the 'gap' for the crane in the roof require that the crane only traveled in that gap? What would happen if you needed to move the load left or right..somewhere there was no gap? Seems like for full versatility there would be a total open space above..sort of kills the idea of a closed paint booth.
    The neighboring business had a huge blast room with adjacent paint room. All the fabrications were set on giant trailer affairs and pushed in with a forklift. The doors were then closed and "Bob's your uncle"!
    Your crane idea would be super if you could figure a way to make it viable and at the same time seal the paint booth up.
    Stuart
    Oct 2006
    Woodland Hills, Ca. and some times Hutchinson, Ks.
    2,358
    19
    605
    Kinda like Stuart mentioned,
    My shop was where they made the first 6K Parana Iron Workers, there are several bridge cranes, the blast room and spray booth are sealed off and accessed by jib cranes that can swing into the area. There are crane rails inside the blast room but no bridge I think the used a manual chain hoist an free floating bridge in there. The paint booth is inline with the blast room and sliding barn doors on both sides allowed transfer. The floor is smooth and I think they used carts or dollies, the big iron workers made here weighed 5~6000
    I also know a guy that has a powder paint line with a racetrack overhead conveyor system. The load parts from pallets or roll them through with carts if to big to hang. Even just getting a bridge crane to exit a building without a spray booth type requirement is a major project and they don't seal well. Opening and closing any aperture above a spray booth is going to introduce dust no matter how you slice it.
    Steve
    Jan 2005
    The Netherlands
    6,166
    316
    1687
    Perhaps a sliding ceiling under the rail of the crane
    Eighter span the 30' or te 45'
    You could hang it in rails to the roof if you span the 45'
    peter
    Oct 2014
    South Dakota
    83
    7
    The load would still have to travel thru the doorway into the paint room, then it CD travel left or right once through the door.
    We are coating ag items where finish is not as critical as body shop. Currently either painting outside or right in the same area we build. So anything will be an improvement. More concerned about keeping fumes and overspray out of the shop than keeping dust from coming in..... .paint room design another topic. Fans, heat recovery, etc. No way we can afford a real commercial paint booth the size we need right now.
    Jan 2005
    The Netherlands
    6,166
    316
    1687
    You are painting airless I hope ?
    Less fumes Less overspray Much faster No bodyshop quality
    Peter
    Oct 2014
    South Dakota
    83
    7
    I wish... Pressure pot we can drop a 5 gallon bucket into. Place I used to work went from airless to air assist.
    Oct 2006
    2,358
    19
    605
    Have you considered elcetrostatic, before power paint was popular electrostatic was the go to system for production.
    Steve
  11. #11
    Jan 2005
    The Netherlands
    6,166
    316
    1687
    I used a 400 bar system once For high viscosity paints on construction
    That went real smooth It produced little fumes
    Peter
  12. #12
    Oct 2014
    South Dakota
    83
    7
    I've never used electrostatic but would love to try it.
