Hydraulic pump Yale forklift ID help
Results 1 to 8 of 8
    Jan 2020
    Florida
    Default Hydraulic pump Yale forklift ID help
    Good day fellow members.
    I've been stump for the last 3 years trying to ID a hydraulic pump for my forklift. Its a 1968 yale G82c -20 serial 167537. The hydraulic pump was made by cessna. The model number is 24200 2c I have not seen a pump like this before or even a replacement that comes close. I don't want to get rid of my lift because it is perfect for what a need and used it for. Any help would be greatly appreciated. Thanks in advance
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,230
    1100
    666
    Have you drug it to a few hydraulic shops asking if they can rebuild it? 3 years without a forklift?
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    9,013
    1473
    2428
    Hyd pumps are usually not rocket science. Unless there are broken gear teeth of course, or galled housings and shafts, with a little effort, some surface grinding on the worm end plates and/or housings, and they can be reworked enough to get them back in service. Might be a 5 year project for you, but hey....
    Jan 2020
    Florida
    Well of course,when I take it to them they act as if it fell from space or foreign object.I have other lifts.
    Nov 2017
    Kansas
    329
    74
    152
    Eaton bought the cessna hydraulic division some many yrs ago. Hope that helps with your search
    Dec 2012
    AUSTRALIA
    2,263
    10
    688
    When you are in the hydraulic repair business ,you quickly learn to "not" recognize old machine specific pumps......complete waste of time ,because the machine they are fitted to isnt worth anything,and you waste time time on the pump,only to be met with shock horror...how could it cost that much?.....If you have a decent workshop ,you will be able to adapt another pump.......however ,at a glance ,the OEM pump seems to have a demand flow /splitter valve inn the end ,probably to work the steering .The simple way round this is stacked pumps,the steering usually a small vane pump,mounted on a bigger gear ,or axial piston for lift and tilt.
  7. Likes dalmatiangirl61 liked this post
    May 2016
    Tennessee
    440
    59
    209
    Take it apart and see what's wrong with it. What was the problem? leaking or low pressure? If it is just leaking, that's an easy fix. If you have low pressure and/or flow it could be more involved. Usually the plates and end of the gears are worn, from years of use and contaminates in the oil.
  9. #8
    Aug 2015
    Illinois
    1,423
    1014
    618
    My guess it is a custom pump made for Clark. I would start looking for vendors that handle and/or recondition used forklift parts.
